LT77 shifting vs R380 - Defender Source
Old January 25th, 2013, 07:21 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I know, this has been discussed in previous threads, and I have read through them for a few hours but not found the answer to my question.
I have a 94 with the LT77. This may sound silly, but what is the correct manner to shift? If I am in 1st, and firmly bring it right to 2nd, I get a slight vibration, not grinding, no noise, but kind of a gear finding feeling. If I shift from 1st, slight pause in Neutral (.5 sec to 1 sec) and then go into 2nd, it is perfect, no feeling of vibration or anything. Is the 2nd way of shifting the "correct" way for this tranny? Thus the reason why some in the US market did not like and had the dealer switch to the R380?
I have to say it takes some getting used to, as I am just used to going right from 1st to 2nd no pause just slam and go. Is this the euro type shifting I am trying to get used to?
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 25th, 2013, 07:31 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
The 2nd way is it. You need to feel it out and let the gears align as opposed to slamming it. Its not a 911. Treat it like a woman.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 25th, 2013, 07:48 PM
EVERY gear box needs to let the synchros mesh. You need to have a sensitive hand and feel it.... Slight pressure against the synchros and it will fall into gear when everything is aligned. Forcing the shift wears the synchros out.
There should not normally be much of a pause required when upshifting. It could be partially worn synchros or use of the wrong oil. Do you know what oil is in it?
Old January 25th, 2013, 07:52 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for advice guys, I think it's just going to take some patience and getting used to it. Hell I haven't even put 100 miles on her yet. Had tranny oil checked by my service guy, it looked great. The pause is seriously like 1 sec and it slides in no issue. I plan to drain out oil this spring and put in new.
Quick question, I need a new shifter knob, are these available for the lt77? Didn't find them on Rovers North.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 25th, 2013, 08:05 PM
Yes, but what is it? To thick or too slippery of an oil will cause them to shift slow.
Old January 25th, 2013, 08:10 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
No idea what brand or type, previous owner had that done. I want to put in Redline Auto trans fluid when I change it out.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 25th, 2013, 08:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
Auto fluid?
Old January 25th, 2013, 08:58 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I said same thing but my mechanic said auto fluid in a manual tranny??? I assume he knows what he's talking about.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 25th, 2013, 09:53 PM
You should use Redline. MTL or similar manual transmission fluid. The original spec was ATF but this works better.
Old January 25th, 2013, 09:56 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Shift slowly and you will be rewarded.
Don't force it into any gear, including first when you're stopped.
Old January 26th, 2013, 09:14 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
On a prior post you inquired about what tranny fluid to use. The consensus was Redline MTL. Guess you found the mechanic that knows better than this group.
r380
R380 and LT77 Gearboxes OBXrover For Sale - Parts 5 December 6th, 2012 09:41 AM
LT77 or R380? MAX711 Defender Technical Discussions 3 October 1st, 2010 02:29 PM
Wanted: R380 or LT77 for project Coiler Wanted 8 March 9th, 2010 12:38 PM
LT77 crapped out on 200Tdi - swap in R380 ? metric Defender Technical Discussions 8 June 11th, 2008 11:58 PM
UK rebuilt LT77 R380 FS SafariHP The Vendors Loft 0 June 11th, 2008 05:46 AM
