LT77 shifter? - Defender Source
Old March 4th, 2013, 06:12 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
LT77 shifter?
Turns out I had the wrong shifter on my 110, couldn't shift t/c into low lock. Got the right one, thanks Doug. But now my had is really close to my Mud UK CENTER dash setup. Anyone else have this issue or a solution?
Picture of old and new shifter someone asked what I had.
Correct one on the left, one I was using on the right.
Old March 4th, 2013, 06:30 PM
Weird. I have never seen the second shifter, I wonder what it is off of? You can rotate the shift to put it at a different angle which might help.
Old March 4th, 2013, 06:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Heat & Bend... if repositioning on the splines doesn't work.
The shifter can be repositioned because of the splines.
If this becomes exhausted and you still cannot find a favorable location, heat the round lever part with a torch and when red it will easily bend into the desired position.
If you are very careful, it can be done in place as long as the flame is small so it won't effect the interior, but is best done outside the vehicle with gradual bends each with a trial fit. Obviously the knob needs removing for the torch method.
Hope this helps.
RDavisinVA
Old March 4th, 2013, 07:54 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
At the arrow I assume.
Old March 4th, 2013, 08:08 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes or the other side of the thick area.
RDavisinVA
Old March 4th, 2013, 08:37 PM
one on the right is an lt95 4spd shifter.
Old March 5th, 2013, 04:09 PM
Mike_D90's Avatar
Mike_D90
Mike T
87 200 TDI - D90
I also had the problem with the LT77 shifter banging into the MUD front console when moving into both 3rd and 5th gear (actually my hand banging into the consule, not the shifter). I ended up removing/turning the shifter a few degrees and now the 3rd and 5th gears stop before my hand hits. The angle of the shifter feels about 5% weird and stretched when in 1st or 2nd though - but 95% isn't bad!
New Shifter Boot LT77 Rosproline157 For Sale - Parts 6 January 27th, 2013 07:21 PM
LT77 Shifter Knob Rugbier Defender Technical Discussions 3 November 3rd, 2009 04:35 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
After market ZF shifter? headdamage Defender Technical Discussions 0 August 23rd, 2005 03:42 AM
95 D90 Shifter 4x4 Vadim Defender Technical Discussions 4 September 21st, 2004 11:52 PM
