LT77 rubber plug help? - Defender Source
Old August 14th, 2016, 02:49 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Was changing some fluids on my truck and noticed some red transmission fluid coming out of an area underneath the cubby/middle seat. It appears to be coming from this deteriorated rubber plug next to what I believe is the reverse light switch. Tried searching couldn't turn anything up. Can anyone tell me the part number of what is supposed to be here? I doubt what is there is original.
Plug installed
Plug removed (it just pulled out)
Said plug
Old August 14th, 2016, 03:05 PM
Parts catalogue says part number 608246. Same as transfer case fill and diff fill and drain.
Old August 14th, 2016, 03:23 PM
AdamSanta85
91' D90 200TDI
I saw that in some pictures but my hole isn't threaded, and it doesn't appear like it ever was.
Old August 14th, 2016, 03:29 PM
Yah. It looks like a frost plug type thing but it is not on the parts catalogue.
Old August 14th, 2016, 03:35 PM
AdamSanta85
91' D90 200TDI
Exactly what I was thinking. Maybe I can just caliper it and get a freeze plug. I figured this would be a factory thing.
This is supposedly an LT77 (although my reverse sensor looks different). It kind of looks like a freeze plug in this picture. Also the upper piece appears to be attached with silicone while mine appears to be a gasket. Not sure of the significance.
Old August 14th, 2016, 03:39 PM
I would send a note to Ashcroft. They will now what to use and they are good at getting back.
Old August 15th, 2016, 12:32 PM
AdamSanta85
91' D90 200TDI
Ashcroft knew the part and is sending me one. Nice fellow.
With my new found clunking I am sure I will be calling him sooner or later for a tranny (output shaft) and transfer case (input shaft).
Old September 5th, 2016, 02:19 PM
I was looking at something else today...and noticed that in the notes on the page, it says the part number...
597586
597586 | Cup Plug - Paddock Spares
Old September 5th, 2016, 02:55 PM
AdamSanta85
91' D90 200TDI
597586
Good find! That is exactly what Ashcroft sent me. Didn't know it had a part number.
Old September 5th, 2016, 03:07 PM
And looking further, it is a 1" frost plug used in the engines as well.
Old September 5th, 2016, 06:24 PM
jafir's Avatar
jafir
Jafir Elkurd
Are you using microcat or a paper/fiche catalog? In microcat if you look up the LT77 shifter and then press DEL for the "superwindow" it shows up but just as a non-indexed part. It's in parenthesis near the end of the list.
Old September 5th, 2016, 06:35 PM
Paper. There is a note below the list that says "the screw in plug 608246 is also replaced by cup plug 597586". I may have been looking online at the time and the note is not in the online catalog.
I must assume early trucks were threaded and had a fill plug and it was deleted early on. Too bad, really, as a big fill plug would be nice.
Old September 5th, 2016, 07:07 PM
Naplm00
Matthew
I'd probably just stick in one of these
https://www.google.com/url?sa=t&sour...UIGH4pq_T3Pyfg
rubber
Freeze plug/exspansion plug replacement WildBoar Defender Technical Discussions 5 March 27th, 2015 02:16 PM
Lost rubber plug Landyman1 Defender Technical Discussions 3 March 14th, 2014 04:23 PM
Rubber plug on Bulkhead Rugbier Defender Technical Discussions 4 November 25th, 2012 07:57 PM
Part Number Help - Windscreen Rubber Plug Wolf Fabrication Defender Technical Discussions 3 February 9th, 2012 07:06 PM
Rubber Plug for Battery Compartment jbird Defender Technical Discussions 1 June 6th, 2004 12:12 AM
» Defender Registry
Ninety
The Dro
Ralph
modrover
Add your Defender
