LT77 Rebuild? - Defender Source
Old December 8th, 2012, 06:26 PM
Abrooks's Avatar
Abrooks
Tony Brooks
LT77 Rebuild?
My 110 was originally a 2.5d. The PO converted it to a 200tdi (in the UK) in large part because apparently the existing gearbox was bad. He sourced a 200tdi disco and swapped the drivetrain (including transmission) over. Consequently the disco gearbox lever is coming up through the front of the seatbox. The existing gearbox feels OK with the 2nd gear synchro in the expected state of crankiness, but there's no rush to swap it out save to position the shifter in the "right" place.
I happened upon a defender LT77 locally that I picked up today more out of opportunity than anything else. The owner drove with it for a few thousand miles and said that it shifted fine, "except for an occasional thunk when it was cold that may have been due to a very worn clutch". The mainshaft splines look remarkably good, but what else can/should I do (up to a rebuild) to ensure that it's in good shape while I have time? I've read up on the rebuild documented here. Is there a good way to inspect this thing short of a complete teardown to ensure it's in good shape before an eventual swap? How nasty a job is a complete rebuild? I see Ashcroft sells a kit for 140.
Best next steps?
Old December 9th, 2012, 04:14 PM
Abrooks's Avatar
Abrooks
Tony Brooks
anyone?
Old December 9th, 2012, 08:28 PM
It is no harder than rebuilding any other manual gearbox. Make sure it is a "G" or "H" suffix though as the older ones are not strong enough to be worth the effort behind a 200TDI.
Old December 17th, 2012, 02:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Finally getting some miles on the 110 and the second gear syncro in the (disco) box ain't what it could be. Since I've got this one sitting here I'd might as well rebuild it or have it rebuilt -- anyone done this themselves?
Old December 17th, 2012, 03:03 PM
Never done an LT77, but the R380 is easy enough. The big thing is to check to make sure the synchro hubs are ok. If they are bad they are spendy. The balk rings are cheap.
rebuild
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Lt77 TexasD-90 Defender Technical Discussions 4 November 8th, 2005 04:39 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
