Lt77 Output shaft replacement - Defender Source
Old December 8th, 2005, 08:59 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm starting to narrow down the problems in my Defender, and I think much of it may be related to the infamous shaft wear issues. It's a very early '94 with the LT77. I had to have the transfer case repaired for an unrelated shifter issue about 2 years ago under warranty that required a complete teardown, and the receipt says 'output shaft replaced'... but I won't know for sure until I inspect it. I don't know if they replaced the input gear and marked it wrong on the reciept, or if they replaced the output shaft but not the input gear.
I know you can replace the input gear in the transfer case easy enough, and I plan on inspecting that this weekend. But if the output shaft on the tranny must be replaced, can I get away with only pulling the transfer case? or does the whole tranny need to come out as well?
I've seen old postings on other forums that support both ideas, but never anybody saying "I' done it." If I have to get a new tranny, I have to get a new one.... but I'd prefer not to if I can get away with it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 8th, 2005, 09:52 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Hans,
Transmission output shaft replacement on a manual trans requires completely dismantling the transmission...for either an LT77 or R380. The output stub shaft on the ZF4hp22 Automatic can be replaced with the trans and t-box in the car.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 8th, 2005, 10:54 PM
Hans's Avatar
Hans
Hans Haase
Well..... crap.
Won't know for sure until I pull the PTO cover off to inspect the gear, but I really can't afford a tranny at the moment considering I already need tires. I'll know more on Saturday.
-Hans
My oil line fix
Old December 9th, 2005, 11:36 AM
pendy's Avatar
pendy
jim pendleton
89'd90
You could pound nails in between the output shaft and input gear like they do in third world countries. Or like the brits do before they sell them on to US.
legend in my own mind
Old December 9th, 2005, 12:45 PM
Hans's Avatar
Hans
Hans Haase
LOL if it all ends up having to get replaced anyways, I may just do that to get me through until spring. Anything to keep me from being forced into the CJ as my daily ride.
-Hans
My oil line fix
Old December 9th, 2005, 04:33 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Who would do such a thing
Mike Hammond
ac
Lt230 frt output shaft bearing Uncle Douglas Defender Technical Discussions 9 December 15th, 2009 08:14 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Special tool to replace output shaft seals? JimC Defender Technical Discussions 9 August 3rd, 2006 10:23 AM
T-Case output shaft help WhiteD90 Defender Technical Discussions 1 August 6th, 2004 10:13 AM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
