LT77 Oil Seal Collar - Defender Source
Old July 19th, 2011, 12:44 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Hi all!
I'm trying to remove the oil seal collar on the output shaft of my LT77, but it's not budging. I've applied heat (propane torch), and I've already bent up one of these:
http://www.harborfreight.com/14-piec...set-30305.html
Yes, I've removed the snap ring
The armed pullers won't fit, so using those are out.
Any ideas? Given how the parts department at the Austin Land Rover dealer blew me off this morning ("we can't do anything without a VIN"), I doubt they're in the mood to lease out the proper tool. Perhaps a better quality bearing separator? If so, any recommendations where I can get one ASAP in the Austin area?
Thanks.
Old July 21st, 2011, 10:29 AM
michael67's Avatar
michael67
Michael White
110 Tdi
FYI, the Rover oil seal collar pulled also failed - it peeled back the top portion of the groove in the oil seal collar. I ended up hunting down the Snap-On guy and buying their bearing splitter.
Old July 21st, 2011, 11:01 AM
Naplm00
Matthew
Sorry i didn't see this earlier...i used a 3 jaw gear puller and a ultra heavy washer in the center for the center of the puller to push on .
I then heated the collar with a torch and it popped right off
http://www.harborfreight.com/3-piece...set-32184.html
these and i just flipped the arms around
LT77 Oil Seal Collar michael67 Wanted 0 July 17th, 2011 01:17 PM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
