Lt77 main shaft wear - Defender Source
Old August 25th, 2015, 12:34 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Would you call this good to use?
ID:	127969   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 25th, 2015, 12:38 PM
Hard to see with the out of focus pictures, but I would say no. Looks like about 1/3 of the spline is left.
Old August 25th, 2015, 12:41 PM
Trash.
Old August 25th, 2015, 03:58 PM
Naplm00
Matthew
yea i wouldn't use that, maybe just pull the shaft and use it as a clutch tool?
Old August 25th, 2015, 04:06 PM
Originally Posted by Naplm00 View Post
...and use it as a clutch tool?
It is an output shaft....
Old August 25th, 2015, 04:32 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
... and it looks quite worn as this one.
How did you get the inputshaft out of the LT230?
I had to pull it out.
Fitted a Disco transmission afterwards. The owner wants to make a roundtrip through the Alps next week.
I will let you know, when it will collaps.
Old August 25th, 2015, 05:22 PM
roverman2010
1985 LR 90 200Tdi
Kurt yours has 50% more metal left than mine
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 25th, 2015, 06:26 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Well, 50% more of nothing equals nothing.
You know that this issue is the same failure that happens to the new 2,2 litre engines?
It lookes quite different at this place between gearbox and tranny but these shafts are running dry too!!!
It's unbelevable.
Old August 25th, 2015, 10:20 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Certainly could get a few more miles out of it but since your showing a picture of it out, it isnt worth the hassle of putting back in only to do it all over again in short order. I replaced mine earlier this year but had only lost 30-40% of the splines. A month or so later I helped a friend do his and the splines were close to letting go....like within a week or two was my prediction.
Ryan
84 110SW County LHD
07 L322 Vogue
LT77 Lay shaft swap between suffixes RollOverRover Defender Technical Discussions 9 August 23rd, 2010 03:14 PM
Rear Main Shaft Seal, how far back to drift in? Neil McCauley Defender Technical Discussions 4 September 12th, 2009 01:28 PM
Maya Culpa series 3 Question about main shaft slop in gearbox airbornrover Series Technical Discussions 2 May 21st, 2009 08:09 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
