LT77 gearbox oil - Defender Source
Old October 1st, 2012, 12:36 PM
melittle
Mark Little
1987 Land Rover 110
LT77 gearbox oil
Being a newbie I went down the path of researching what the recommended oil is for a LT77 gearbox. Of ourse there seem to be as many opinion on what to use as there are owners, and much of the information on the web is not very current. I'm thoroughly confused now since there is no definitive spec, unless I just haven't found it? Help....
Old October 1st, 2012, 12:41 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I use Red Line MTL 70W80 GL-4:
- Popular for BMW, Honda and Acura, Ford Focus, late-model Mini Cooper, Land Rover/Range Rover LT77S, Dodge & Jeep NV1500, NV3500 and NV5600 truck transmissions
- Popular replacement for and improvement over GM Synchromesh® (#12345349) and Auto-Trak II® (#12378508) and Chrysler spec MS-9224
- Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
- Offers quicker shifts, perfect synchronizer coefficient of friction
- Eliminates notchy shifting, even when cold
- High performance gear protection and longer synchro life
- Satisifies the gear oil viscosity requirements of 70W, 75W, 80W, and motor oil viscosities of SAE 30, 10W30, and 5W30
- Recommended for GL-1, GL-3, and GL-4 applications as well as where most special synchromesh fluids are specified
Old October 1st, 2012, 01:03 PM
The factory spec is ATF. These days there are a lot of low viscosity manual transmission fluids that are a better choice.
Redline MTL is easy to get and works very well.
Old October 1st, 2012, 01:49 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I use Redline MTL in mine
Old October 1st, 2012, 03:03 PM
Naplm00
Matthew
yea the MTL is awesome, cured some sloppy shifting in mine
LT77 Oil Seal Collar michael67 Wanted 0 July 17th, 2011 01:17 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
