lt77 cold weather, hard to shift - Defender Source
Old December 10th, 2010, 10:15 AM
discotdi
Todd Miller
Land Rover
So, I have have an LT77 filled with Redline MTL. Now that we have had some cold weather I find it nearly impossible to shift into second until the engine and tranny are heated up. Third can be difficult too. Is there a better fluid for cold temps or is my tranny on the way out?
Old December 10th, 2010, 10:20 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
My Haynes manual recommends MTF-94 which you can get from any MINI-Cooper dealership. It has been cold here and I am not having problems...
Old December 10th, 2010, 10:40 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Likely just the fluid, not the tranny. I've had that happen with every manual transmission I've ever driven when it starts dropping under freezing.
My oil line fix
My 100k stopped odometer fix
Old December 10th, 2010, 11:32 AM
Redline MTL is in my R380. Same scenario until it gets warm and the tranny was brand new in May.
Old December 10th, 2010, 11:53 AM
discotdi
Todd Miller
Land Rover
ok thanks for the advice. I guess I will just baby it more.
Old December 10th, 2010, 01:09 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
LT77s require ATF type F not dextron or redline
type F has more friction for the syncros
cold temps just make it worse
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old December 10th, 2010, 01:10 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have the same problem with mine after a recent fluid change in my LT77. I used regular 80W90 gear oil in everything underneath. Did I use the right thing?
I was told that it would be fine to use ATF in tranny and the problem would go away. Would it be advisable to change to ATF?
Old December 10th, 2010, 01:15 PM
To each his own. I have been running MTL in Lt77's with superior results to atf for years as have most everyone I know with Lt77's. In practice it has signifigantly reduced 2nd gear crunch on worn syncro's in transmissions that had been filled with type F.
Old December 10th, 2010, 01:38 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I used Amsoil manual transmission fluid (syncromesh) in my R380 and like it very much. I'm not sure if that helps with the LT77 question though.
http://www.amsoil.com/storefront/mtf.aspx
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old December 10th, 2010, 02:19 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Try Royal purple's "Synchromax". It got rid of all the erratic/crunching shifting issues I had on the R380's and the LT77's. It seems to put up with the severe temp drops we see here in Wyoming. And for the guy that put 90w in his tranny....good luck with that one! Try flushing it with a couple cycles of cheap ATF and then put the Synchromax in. Good luck!
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Excessive Cold Weather Exhaust boshea Defender Technical Discussions 3 January 9th, 2005 02:44 PM
1st really cold weather questions mspell Defender Technical Discussions 6 December 20th, 2004 08:40 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
