LT77 clutch job...difficulty - Defender Source
Old April 24th, 2015, 12:57 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I imagine with 82k miles my 88 D90 probably has the original clutch...its starting to engage about 2 inches from the floor....it also is making a noise at idle unless I engage the clutch...i am thinking throw out bearing....unfortunately I can't get the truck into my garage where I have a lift...can most decent mechanics tackle this who has never worked on a Rover?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 24th, 2015, 01:02 PM
Sure. No different than any other rear drive vehicle.
You should plan, though to replace all of the throwout parts and slave cylinder and the rear main seal at the same time. There are options for HD throwout bearing housings.
You don't need a lift. An engine hoist or tranny jack on the side of the road will do.
Old April 25th, 2015, 12:31 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Pedal is pretty close to the floor today...starting to question the clutch or could it be the slave from the pedal to the clutch itself?
Old April 25th, 2015, 12:35 PM
Most likely hydraulics.
Old April 25th, 2015, 12:39 PM
I had the same issue, the clutch MC was the culprit. It's a PITA to remove on a LHD truck so I went with a genuine part instead of an aftermarket unit.
Old April 25th, 2015, 12:47 PM
You just have to know the secret trick to change the master. If changing do the slave and hose as well. Make sure they are OEM branded units. The Chinese one have a high failure rate.
Old April 25th, 2015, 12:54 PM
The trick it to unbolt the brake MC as to avoid taking off the left wing. Yes but it still is a PITA requiring various mechanics yoga positions including mangled, twisted down dog.
Old April 25th, 2015, 12:58 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
This is a RHD unit so I hope a tad easier...will order one up before I start playing with the clutch itself...
Old April 25th, 2015, 12:59 PM
Nope.
Old April 25th, 2015, 01:00 PM
RHD, piece of cake but wait till you have to change the accelerator MC. You will be lucky to even locate it let alone replace it.
Old April 25th, 2015, 02:30 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Which part of the accelerator?
Old April 25th, 2015, 02:42 PM
I've read about people saying how much of a pain it is to replace the clutch mast cylinder, but I found it to be pretty easy. I just unbolted the brake pedal housing and booster IIRC.
Old April 25th, 2015, 03:07 PM
the rover shop
shayne young
Dave is special,.. He has an accelerator master cylinder...for that hydraulically operated accelerator linkage setup..
Old April 25th, 2015, 04:38 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Just checked and the reservoir is very low...at the bottom of the neck...going to try and refill and see if I can get some more pedal...all the piping looks but cant see completely underneath....however there is so much residual fluid drippings on the underside it's hard to tell what and where there are leaks...at least I stopped all of the leaks on the top side of the motor...
Old April 25th, 2015, 04:45 PM
LOL
That is the exact symptom that my failing MC had. If you have fluid dripping from the bell housing it is the slave cylinder.
Old April 25th, 2015, 04:54 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That is the exact symptom that my failing MC had. If you have fluid dripping from the bell housing it is the slave cylinder.[/QUOTE]
I assume that you have to separate the bell housing to get to the slave or is it an outside job? It sounds like the throw out bearing may be bad too so if it has to be opened up I guess I should replace the clutch, throw out and slave all in one shot...
Old April 25th, 2015, 07:56 PM
To do the slave you can do it without opening things up. To do the throwout bearing, fork, clutch itself you need to separate the tranny from the motor.
Step by step slave replacement
Step by step clutch master replacement
Buster does good work and ah like his narrations.
Old April 25th, 2015, 08:06 PM
I have seen a few where the slave cylinder leaked which I believe led to the failed throwout bearing. If the bearing is noisy it needs to be replaced.
Old April 25th, 2015, 11:06 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
BTW is it the Release or throw out bearing or is it just the same name...was looking at RovahFarm and they have a kit that is the Pressure Plate, Clutch, and Release Bearing...
"Clutch Kit - 'Valeo' - Heavy Duty 9.5"
Ref: LR009366HDV / Price $269.00
Application: Fits all diesel 4 cylinders. 2.5NA, TD, 200TDI and 300 TDI not TD5 - Kit contains, friction plate, pressure plate and NSK release bearing - S/s from STC8358"
Old April 26th, 2015, 12:29 AM
This isn't something you want to do again any time soon. I would go with LR factory parts if it was me and not aftermarket.
clutch
Difficulty of Replacing Dip Switch? bradfordish Defender Technical Discussions 1 January 17th, 2014 12:36 PM
Left over stuff from my Clutch Job - Seals and what not for trans, transfer, etc bjf For Sale - Parts 11 May 22nd, 2012 09:10 PM
Help - difficulty zipping sides back on to softtop advnirvana Defender Technical Discussions 7 June 7th, 2009 02:56 AM
Difficulty shifting gears martym Defender Technical Discussions 3 November 4th, 2006 04:38 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
