LT77 clutch job...difficulty - Page 2 - Defender Source
Old April 26th, 2015, 12:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, if you replace master/slave there is a place that rebuilds them for a permanent fix. Believe they put in a bronze bore or something. You can do a search easy enough to find them or someone that recalls may chime in. I'll do it when mine fail again-- I last did this job nearly 10 years ago, knock on wood...
Old April 26th, 2015, 12:48 AM
Here is the place recommended in another thread:
Apple Hydraulics: Brake and clutch
Old April 26th, 2015, 12:51 AM
the rover shop
shayne young
Ed angel and I changed a clutch in a campsite in Mexico with a ratchet strap and basic hand tools.. For the record a ford ranger clutch disc is pretty much the same as a land rover one if ever you get in a pinch in some remote town down in Mexico..... Ask us how we know...lol...
Old April 26th, 2015, 09:39 AM
Originally Posted by icnsltmfg View Post
BTW is it the Release or throw out bearing or is it just the same name...
Same thing.
I think that is typically done when the bore is pitted. I might be wrong, but that's my understanding at least.
Old April 26th, 2015, 09:14 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
One last Question...do you have the part number on the main seal that should also be replaced...if this thing is being done I would rather not have to open it again...is it the seal that goes around the shaft? I think it is this one for the input shaft...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old April 26th, 2015, 09:30 PM
If you order a rear main seal, you may as well get two in case you screw one up during installation. Nothing worse than being held up on a big job like that because of a small yet essential part.
Old December 15th, 2015, 10:20 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Adam, what clutch did you end up getting? Seems like too many choices out there.
Old December 15th, 2015, 10:41 AM
scrubs
henery
1974
It's not on the most difficult level as things go, did 2 this past year.
Do yourself a favor, if you can pressure wash the bottom to stop carp falling into your face, then spray the cross members with some PB Blaster or equivalent.
Might look at getting a pilot bushing, cheep enough to have on hand just in case your's is worn badly.
Don't be intimidated by it, just nuts n bolts, I put all of them in separate coffee containers for each area.
A big help for myself was to lift the rear of the engine and use 4" bolts to guide the gearbox back on.
For a novice like myself it took a full weekend both times but the second was easier n quicker.
Best advice was given ealier, buy genuine parts,too deep to be cheep.
clutch
Difficulty of Replacing Dip Switch? bradfordish Defender Technical Discussions 1 January 17th, 2014 12:36 PM
Left over stuff from my Clutch Job - Seals and what not for trans, transfer, etc bjf For Sale - Parts 11 May 22nd, 2012 09:10 PM
Help - difficulty zipping sides back on to softtop advnirvana Defender Technical Discussions 7 June 7th, 2009 02:56 AM
Difficulty shifting gears martym Defender Technical Discussions 3 November 4th, 2006 04:38 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
