Lt77 - Defender Source
Old November 6th, 2005, 05:39 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Lt77
I know most of you are probly sick of hearing my questions, but I've got another one. Is the LT77 transmission terrible? It seems lots of people have put the R380 in the older 94s. What is wrong with the LT77? Should I pass on a purchase oprotunity because of the transmision. This will be a daily driver. Any help and advice will be greatly appreciated.
thank you,
Martin
That is why it is called a short cut. If it was easy it would just be "the way."
Old November 6th, 2005, 06:08 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I personally, I haven't had any issues with the LT-77. The only REAL annoyance is that the reverse gear is in an odd location. Some of the earlier ones did have troubles with premature wear on the output shafts, which is the only thing I would be concerned with. There are ways to check for that, but I don't remember the details (should be able to search for it in the forums somehow)
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 6th, 2005, 06:47 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
The output shaft wear could be an issue. Search for method of determining wear, it's pretty easy and is evidenced by play in the driveline. 115,000 on mine and still no major play. 77s shift hard and the syncho gets weak in 2nd and 3rd (I always have to pause going into 3rd).
380s are the solution. Of course you could get a Quaffe 6 speed sequential bolt-in replacement -- that is if money is no object!!
DW
Old November 6th, 2005, 07:20 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My 77 is fine. I did not have the cross drilled output shaft, but I did put a reoiler kit on it at about 65K miles. Every 380 that I know of has synchro issues, so do 77's but no worse. I would not pass up an opportunity if it had a 77, but when I replace mine it will be with a 380 because I can get them cheaper. Of course I might just rebuild my 77...
Old November 8th, 2005, 04:39 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
With a cross drilled gear on the output shaft wear is greatly reduced. All my trucks have LT77's and the worst one to drive is the one rebuilt by Ashcroft for much money.
Mike Hammond
LT77 and V8 Stork17 Defender Technical Discussions 4 November 7th, 2008 03:15 PM
F/s Lt77 Paul Grant For Sale - Parts 5 July 27th, 2008 01:00 PM
Rebuilding LT77 Trans... Stmpede Defender Technical Discussions 11 March 21st, 2007 08:24 AM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
serial # differences from lt85 and lt77 draaronr Defender Technical Discussions 1 August 30th, 2004 11:56 AM
