LT77 5th gear stop leaking.. - Defender Source
Old January 19th, 2018, 03:30 PM
supertreeman
Nick C.
1985 D90 2.5NA
developed a leak here, looks like its been leaking for a while. Parts manual shows no gasket. Surprised fluid reaches that high in the box. Anyone else seen this leak before? Lousy picture but its FRC7313..(at least I think it is)..
ID:	347265   Click image for larger version
Old January 19th, 2018, 03:42 PM
Naplm00
Matthew
It leaks from the grease that is packed Into the shifter remote above it. The grease will settle at the bottom of the remote over time. Super easy to fix,. Pop it off, clean it up and back rtv it!
Old January 19th, 2018, 04:13 PM
supertreeman
Nick C.
1985 D90 2.5NA
Thanks! Sounds easy enough..
Old January 19th, 2018, 04:56 PM
Naplm00
Matthew
I actually find it easier to get to this from above not from Below. It may be a good time for you to clean out the gearbox remote/shifter housing and re grease everything. There are a few gaskets up there that you can renew as well. A trip to the coin-op car wash before you do this job will make it much more pleasant. Hit that area with high pressure water and engine degreaser
Old January 19th, 2018, 05:21 PM
supertreeman
Nick C.
1985 D90 2.5NA
Iíve been meaning to de gunk everything but itís been so damn cold here.
ThAnks for the suggestions. Planning to remove trans tunnel and really clean all I can.
Old January 19th, 2018, 05:34 PM
Naplm00
Matthew
Yea I hear that! If you have a spartan interior like mine... I power washed the trans from the top as well with the hump off. Juts laid tarps over everything.
If you are gonna take the time to do it well rent a legit power washer, makes it much easier
top
95 D-90 5th gear broken DG Rodgers Defender Technical Discussions 4 February 19th, 2009 10:06 AM
5th Gear Issues bdthornton7 Defender Technical Discussions 0 August 17th, 2008 03:33 PM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
