LT77 5th gear issue - Defender Source
Old February 8th, 2016, 08:01 AM
rustyplumber
Russell
none (yet)
LT77 5th gear issue
Hi all, the issue I'm currently having is weird. 1-4 gears shift fine like they usually do, but when shifting to 5th, it goes back into 3rd. It's the exact same position that 5th has been in for since I could remember. Only had the issue after I did some mudding a couple weeks ago. Already checked the 5th gear stop and adjusted it but same issue. Like I said it goes exactly into 5th gear but it's 3rd, which is weird.
Old February 8th, 2016, 09:07 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The screw connecting the rod with the bowl is tight?
Old February 8th, 2016, 10:27 AM
rustyplumber
Russell
none (yet)
The grub screw? It's pretty tight in, I'll double check it but I didn't mess with it
Old February 8th, 2016, 12:05 PM
rustyplumber
Russell
none (yet)
Grub screw good, any other suggestions?
Old February 8th, 2016, 12:15 PM
I would guess the selector fork for the 5th gear shaft has come loose. The whole box needs to come apart.
Old February 8th, 2016, 03:07 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
It looks like this.
Clicking in 4th and 5th gear Cred Defender Technical Discussions 6 August 11th, 2010 04:49 PM
95 D-90 5th gear broken DG Rodgers Defender Technical Discussions 4 February 19th, 2009 10:06 AM
5th Gear Issues bdthornton7 Defender Technical Discussions 0 August 17th, 2008 03:33 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
