LT230T Swap - Defender Source
Old June 15th, 2016, 08:44 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
LT230T Swap
As I understand it, a NAS D90 with a LT230T 1.222 can take a transfer case transplant from a Defender 110 & 130 and a Discovery I and Range Rover Classic - not a Discovery II?????
If this is the case, does anyone know the model number (stamped on the transfer case) range that will fit my D90? The current number is (LT230T 1.222 ratio) 32D286274E.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old June 15th, 2016, 09:21 PM
just get the gear ratio you want, and the highest suffix letter you can find (Q?). defenders need the 4 threaded holes for the parking drum mount. I have a D2 tcase in mine. I had to drill and tap the holes (easy and documented DIY job).
Mark Kellgren
KM4BOR
Old June 15th, 2016, 09:28 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
I thought some suffixes had weaker gears than others...
Just found the post... It's the q you want to avoid.... They made it quieter but sacrificed strength.
Old June 15th, 2016, 09:43 PM
True, as in the Q case they went to a higher "tooth" count for the input gear (can't remember exactly what, but I think it was 36-tooth versus the earlier 28-tooth).
That said, "weaker" is a subjective term...I've never heard of too many folks (besides myself and Buck when he was running KOH) breaking an LT230. Mine broke because it had been "remanufactured" with some crappy very early innards.
When I broke my tcase, I went with a D2 case and adapted it to my 90....it's a later-suffix case with the 36-tooth input gear. I'd wager that this case will outlast me and the truck...I'd certainly not hesitate to slap a Q suffix in any Defender, trail rig or not, without fear or apprehension. And - for the record, it IS actually a bit quieter which is a plus!
Old June 15th, 2016, 10:18 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
True, as in the Q case they went to a higher "tooth" count for the input gear (can't remember exactly what, but I think it was 36-tooth versus the earlier 28-tooth). That said, "weaker" is a subjective term...I've never heard of too many folks (besides myself and Buck when he was running KOH) breaking an LT230. Mine broke because it had been "remanufactured" with some crappy very early innards. When I broke my tcase, I went with a D2 case and adapted it to my 90....it's a later-suffix case with the 36-tooth input gear. I'd wager that this case will outlast me and the truck...I'd certainly not hesitate to slap a Q suffix in any Defender, trail rig or not, without fear or apprehension. And - for the record, it IS actually a bit quieter which is a plus!
Yah... The lt230 is definitely not the weak link in a defender drivetrain. Probably the best part of the whole thing... But if you have the choice.... I'm surprised you can actually hear the difference in a defender with all the other racket going on.
Old June 16th, 2016, 01:26 PM
dsh12
Daniel Hayes
When you reference the Q suffix is this referring to the number stamped on the case? The number on mine is
listed in the original post. No Q in mine.
Dan
Old June 16th, 2016, 01:35 PM
it's the last letter. yours is an E series. each new version gets the next letter.
Mark Kellgren
KM4BOR
lt230
URGENT: Need an LT230T (not LT77) in Richmond, IN JohnC Wanted 9 August 7th, 2013 10:26 AM
LT230T (20D) Input seal michael67 Defender Technical Discussions 5 August 16th, 2011 03:55 AM
1.2 Lt230t RyanS For Sale - Parts 5 March 31st, 2008 07:06 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Lt230t boxerhips Defender Technical Discussions 4 December 7th, 2005 10:01 PM
