LT230T Front Output Flange questions...... - Page 2 - Defender Source
Old March 2nd, 2006, 08:17 AM
kiphartzell's Avatar
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
Update: I had a new transmission brake drum machined for the underdrive and I had the drum, adapter, and the Tom Woods DC drive-shaft balanced as one completed unit. The parts were marked for orientation and put back on the D90. After all of this, I still have a vibration! It was a little better, but I still get distinct vibrations starting around 28MPH. I also removed the middle seatbox cover and t-case boot so I could view the drive train while driving on the road. This did not help to isolated the vibrations, the drum and driveshaft seemed to be rotating smoothly. When I felt the t-case and underdrive, there was definitely a difference. The underdrive had more vibration, but this may be because it is hanging off the back of the t-case unsupported while the t-case is supported by the mounts.
Has anyone heard of a Ashcroft underdrive unit causing unwanted vibrations?
lt230
Front TC output shreik! owen Defender Technical Discussions 3 January 2nd, 2010 11:39 PM
Front output flange lynchee Defender Technical Discussions 6 September 10th, 2009 03:55 PM
DII Front output flange weissbrewer Wanted 5 August 20th, 2007 12:40 PM
DiscoveryII Front Output flange Davis Wanted 0 August 5th, 2007 01:20 PM
