Lt230q - Defender Source
Old March 18th, 2011, 09:32 PM
jhhorse
joe heins
1995 defender 90
Lt230q
Are the LT230Q boxes any quieter? considering one when my noisy (and getting noisier) transfer case goes on my 95 D-90.
Old March 18th, 2011, 10:23 PM
Yes!
Old March 19th, 2011, 06:47 AM
TS888's Avatar
TS888
Tony Sims
1984 110
The are supposed to be, but experiences differ. The story:
The LT230Q transfer box is mounted at the rear of the main gearbox and transmits drive to the front and rear axles via the propeller shafts. The LT230Q, while similar to the LT230T differs mainly in the following areas:
• Helix angle of gears increased to 31 together with an increase in the number of gear teeth thus giving quieter running and an increase in power transmission efficiency.
• Increased length mainshaft input gears together with increased thickness bearing housing and repositioned bearing.
• Redesigned intermediate gear bearings. Redesigned high gear bush giving quieter running
Tony
1984 110 "Smokey" (sold)
Old March 19th, 2011, 10:17 PM
NC Rover
Nick
1971 Series IIa Hybrid
How can you tell which one you have?
Old March 20th, 2011, 06:37 AM
TS888's Avatar
TS888
Tony Sims
1984 110
I think they have serial numbers beginning with 38D or 43D.
Tony
Old March 20th, 2011, 08:50 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
The new one I got from Ashcroft is significantly tighter and quieter than the old non-Q box. They're also stronger so better if you're going to be putting in a higher output engine as well.
Old March 20th, 2011, 02:42 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I switched from the LT230 to the Q and noticed a difference immediately. I even lost quite a bit of "slop" that plagues these trucks.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 20th, 2011, 03:12 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Did you have them install the HD solid cross pin?
Tony
Old March 20th, 2011, 03:17 PM
ajh
Andrew J. Hutton
Not needed for this one, but if I was putting real power behind it with lockers I'd absolutely go for that. I'm thinking about doing one with a Quaife centre for a racer I'm hoping to start working on in the next while. With the 200TDI I'm just not worried.
Old March 20th, 2011, 07:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
While I think this is a good upgrade, I seriously doubt that anyone has put that much more stress on an lt230 than I have. (arrogant I guess, but probably accurate). If you keep your diff locked, and don't try digs, I think the t-case as good as it gets in stock form. Fantastic actually. I like it much better than the atlas in my racecar.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 21st, 2011, 01:42 PM
jhhorse
joe heins
1995 defender 90
Thanks to all the input, I went ahead and made the swap; I guess my old transfer box was getting ready to become a million little pieces on the highway, the LT230Q I had installed, used from a 98 Disco, is virtually silent compared to the original!
lt230
LT230Q on Defender ajh Defender Technical Discussions 1 October 16th, 2010 04:57 PM
Lt230q Twallis45 Wanted 1 October 1st, 2009 04:54 PM
97 Lt230Q for sale RoverC For Sale - Parts 8 May 24th, 2009 10:09 AM
Where can I buy LT230Q parts? Hammertime Defender Technical Discussions 2 May 24th, 2009 07:49 AM
ZF4HP22 and LT230Q t/c RoverC For Sale - Parts 3 June 24th, 2008 08:30 PM
