LT230: What's better? Proper end-float or preload torque? - Defender Source
Old June 28th, 2015, 11:15 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
So in my epic quest to rebuild my LT230 that came with my new-to-me 110, I've encountered a bunch of ups and downs. I've hit a new one that brings a question:
Is it better to have proper end-float on gearshaft splines per the manual, or have proper gear resistance?
Here's an example situation:
After installing and shimming the input gear to have the proper float per the rebuild manual (0.05mm), I have a really low resistance measured at 0.12kg. The unoffical repair manual mentions no specific float measurement, but says that the resistance should be between 1.4 and 3.6kg.
It's important to note that I'm using brand new bearings and can shim the back side of the bearing as needed.
Thoughts?
Old June 29th, 2015, 01:05 AM
edit: i reread your post.
Old June 29th, 2015, 01:08 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
There should be no end float on any of the shafts in an LT230. All the tapered bearings should have some preload.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 29th, 2015, 01:22 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
Using the official LR PDF from Ashcroft's site, but also have an unofficial repair manual that I got from Amazon.
Old June 29th, 2015, 07:47 AM
Rob Dassler is the foremost authority on rebuilding defender gear boxes in the US. I'd take the mans advice.
Old June 29th, 2015, 06:22 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
So Rob, can you confirm the pull-test values for the diff gear assembly, the input shaft, and the intermediate gears once assembled?
Old July 2nd, 2015, 06:38 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Thoughts?
Just doing this ATM I used the 0.05mm pre-load figure for the input shaft (3rd edition L/R t/case manual) and 10lbs on the diff bearings (Maxi-Drive instructions for the 30% low range gears) with new bearings.
Old July 2nd, 2015, 12:09 PM
inquiring minds want to know...does the manual say float or preload?
Old July 2nd, 2015, 03:55 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
You set it by measuring float but the bearing does have preload. You are supposed to measure end float then add a shim that is float + x (where x =.xxx" over). All covered in the book if you want to read. Anybody can download from ashcrofts site too...
Ryan
84 110SW County LHD
07 L322 Vogue
Old July 2nd, 2015, 04:10 PM
Problem is.... 2 thou of end float in an unmeasurable thing, IMO.
Old July 2nd, 2015, 04:31 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
I just did it as per the book John, t/case vertical, input shaft resting in front cone, rear cover bolted down to 18lb/ft and measure the end float with a dial indicator by lifting the shaft. It was repeatable.
Add shim/s to get the 0.05mm pre-load.
Old July 2nd, 2015, 06:16 PM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Measure end float and calculate pre-load, 0.05mm.
The late t/case manuals also stipulate this way to set up the centre diff bearings, but I used the earlier string and spring balance method.
lt230
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Sticky gas level float on NAS110 Neil McCauley Defender Technical Discussions 0 April 23rd, 2014 03:56 PM
Transfer box input bearing preload reb78 Defender Technical Discussions 10 October 29th, 2008 05:04 PM
Tdi proper startup after oil cooler lines replaced artm Defender Technical Discussions 5 August 7th, 2006 11:59 PM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
