LT230 TC drain bolt size? - Defender Source
Old March 19th, 2010, 10:14 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Anyone know the bolt size (and maybe a PN) for the TC drain bolt? I must have managed to over torque it when I last replaced my fluid, as I went to replace my fluid today and it rotated in half leaving half of the upper section in the hole. Luckily the fluid looks pretty decent still and the remaining half isn't letting any drain out...
Old March 19th, 2010, 11:03 AM
JPRO576's Avatar
JPRO576
blueboy
'96 Discovery Tdi
Part # is 599552. Same thing happened on my wife's D1. Ended up having to tap the hole one size up. Can't remember off hand size wise. Just ended up going to the hardware store and getting a new automotive drain plug. Works great. List on the factory plug is about 17 bucks. Hope it helps.
JP
Old March 19th, 2010, 10:22 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Someone please take the big wrenches away from Dave
Matt Browne
Old March 22nd, 2010, 11:31 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Ha, ha. You've witnessed my horrid wrenching first hand....
Why wrench when you can just plug it in Matty...
Not.
drain, lt230
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
