LT230 Stuck in High - Defender Source
Old May 11th, 2015, 05:32 PM
mattwhite
Matt White
94 D-90
LT230 Stuck in High
Long story short, can't get the lt230 in low range. For my LS swap I bought a low miles pre-'99 Disco t-case from a salvage yard. I probably should have checked it over better before I put it in, but oh well.
I pulled the shift interlock solenoid. Also pulled the linkage housing to rule out any issues with external linkages. I can not get the shift fork to move either stationary or rolling as I apply pressure directly to the rod attached to the fork.
Could there be something jacked up with the gears? Also there's a ball detent acting on the rod attached to the shift fork, could it be turned in so far it's not allowing movement?
Old May 11th, 2015, 06:17 PM
Back the adjusting socket screw all the way out and take the detent ball and spring out to see if it's gummed up.
Old May 12th, 2015, 04:08 PM
mattwhite
Matt White
94 D-90
Follow-up: Someone must have been hung over on the lt230 assembly line. The detent ball was cranked in and would not let the shift fork move. Shifts great now.
lt230
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
LT77 and 1.4 high range LT230 evilfij For Sale - Parts 15 April 26th, 2007 12:06 PM
Brake Lights Stuck ON RoverWrecks Defender Technical Discussions 4 August 21st, 2004 11:26 AM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
Stuck in the River! wicks Misc. Chit-Chat 0 February 2nd, 2004 04:27 AM
