LT230 slack - Defender Source
Old October 2nd, 2014, 09:24 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
LT230 slack
One of the problems I want to address this off season is the slack within my transfer case. I have some slack in the input gear/trans output shaft that I will also be addressing. With the front driveshaft removed and the diff lock engaged i can rotate the front flange approx 45 degrees with no movement in the rear shaft. I have checked several other boxes and they have no play at all in the same scenario. This causes a fairly loud clonk when taking up any gear or applying power from a decel. Any ideas as to what may be wrong internally? It is a 1.4 box behind a 200tdi.
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 2nd, 2014, 09:43 PM
Must be the Center diff.
Normal T-case driveline slack? sflash868 Defender Technical Discussions 2 July 14th, 2014 08:22 PM
Slack in Timing Chain 61rover Defender Technical Discussions 3 July 26th, 2011 10:20 PM
Wiper slack dnp Defender Technical Discussions 3 May 12th, 2007 08:14 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
Sean Slack chrisvonc Defender Owners 0 February 24th, 2004 10:38 PM
