LT230 Replacement Questions - Defender Source
Old June 24th, 2016, 04:12 PM
rayjay003
Jason
1987 90 RHD 2.5 Petrol
I am new to the Defender world and am looking for some advice on replacing my transfer case. I have a 1987 RHD 90 with the 2.5 petrol engine. The transfer case does not shift properly and seems to be seized when trying to shift into high; low and neutral seem to be free. It is also making a ticking noise (at least my mechanic says it is coming from the t-case).
I am looking to replace the unit with a used one (hopefully I can find a good deal on the forum!).
My question pertains to the 1.2 versus 1.4 versions. I use the truck to drive around town and to the beach, no off roading (maybe some minor off roading once I get it all sorted out!). Highway use is the priority. I am not sure which version I have (any help to identify it would be great).
Which version would be best for me; 1.2 or 1.4?
Thanks in advance for any suggestions!
Old June 24th, 2016, 04:19 PM
A 1.2 will be too high for that engine. You can tell what you have from the serial number.
Most likely the shifting problem is the external linkage. I've never heard of an internal shifting problem.
Ticking noise could be anything. You can pull the inspection plate in ten minutes and inspect the gears. The transfer case is the most reliable part on the vehicle.
Old June 24th, 2016, 06:34 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I have a 90 with the 2.5NA and put in a LT230 from a Discovery with 1.2 high. It pulls and will do 70mph, on a level road, at sea level with no wind. Mostly.
I don't know if your gas engine will pull or not. But I can tell you that 1.2 are VERY plentiful in junkyards which means they are cheap! Under $200, maybe $150 if you look hard enough.
Buying a 1.4 is a lot more expensive. I'd consider buying a 1.2 if you find one at a good price. If it doesn't work with your engine you will be able to resell it for what you paid and pony up for the 1.4.
Defenders draw attention. Don't buy one if you're shy!
Old June 24th, 2016, 06:58 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
As John advised a 1.2 is too high, ie would over gear it to a point of driving a 4 speed.
A 1.4 is a stretch unless you add a header and less fidley carb.
The 34 with all the contraptions added for fuel anti-run-on and gasoline fume reduction and forced timing changes makes it problematic from the show room, much less 29 years later.
A weber 32/36 will work without issue.
The best option for you is to get your shift linkage working.
Also make sure the diff lock indicator switch is not out of adjustment which can cause some issues if you are going into certain gears if not all of them.
RDavisinVA
Old June 27th, 2016, 11:01 AM
rayjay003
Jason
Thank you for the info. I think I will need to do some more investigating into the issues I am having to see if I can have them fixed instead of replacing the unit.
ac, lt230
LT230 output bearing replacement USLandy Defender Technical Discussions 13 April 25th, 2016 03:51 PM
lt230 tcase mount rhs (disco lt230) Cajun Wanted 8 October 14th, 2015 06:30 PM
Master Clutch Cylinder Replacement: Questions... NC Rover Defender Technical Discussions 5 February 8th, 2011 03:11 PM
Transmission replacement questions cgalpin Defender Technical Discussions 1 August 1st, 2006 12:16 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
