Lt230 Refit - Defender Source
Old December 2nd, 2004, 09:25 AM
Nil
Teague Plain
1994 Defender 90 ST
Thumbs down Lt230 Refit
How difficult is it to mate an LT230 t-case from a Disco II to a 1994 D-90? What additional parts/labor (if any) are required?
Cofion,
Nil
NIL
Non Arte - Sed Marte
Old December 2nd, 2004, 10:54 AM
might lose the diff lock..
Old December 2nd, 2004, 11:12 AM
Now I am no expert but, I think you need the output housing off of the Defender T-case as the one on the Disco does not have the speedo output. And I am also not sure about the input gear, the splines on the autos output gear are a differnt length then those on the R380s. Like I said, this is just from what I have read.
Old December 2nd, 2004, 11:31 AM
you need to change the mainshaft in the trans or find a 2in style input gear for the transfer case. You need to swap output housings in the back and you need to remove the solinoid from the top of the t-case and you need to swap the front flange for the smaller D90 flange or use a DII driveshaft.
All and all $$$$
Ron
see my ad in classifieds for a correct D90 case or find an early disco I case (i have one of those too)
you will also lose difflock if the t-case is from mid 2001-2003
Old December 2nd, 2004, 12:08 PM
Nil
Teague Plain
1994 Defender 90 ST
Lt230
"...see my ad in classifieds for a correct D90 case or find an early disco I case (i have one of those too) "
Ron,
The point of my questions was because of seeing some Disco LT230s on here for sale. My t-case melted this weekend and my mech and I are looking for one to replace it - cheaply. Let me know what you have for sale.
NIL
Old December 2nd, 2004, 12:36 PM
Disco II is hard to fit was my point. I have a 95 disco I with 45k for $400 or a 94 D90 with 80k for $350 both had diff failures which I replaced with used diffs.
I thought you bought a DII and that is why you were asking.
Ron
evilfij at yahoo dot com
both will bolt right on as I pulled the solinoid in the disco I case. No additional labor but I would replace input seal as a matter of course
lt230
lt230 boxerhips Wanted 0 December 7th, 2005 01:39 AM
LT230 Transfer Case jimmy salmon For Sale - Parts 2 December 17th, 2004 07:19 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
3rd Members with 4.75/ARB's and LT230 billnsandi For Sale - Parts 0 January 26th, 2004 11:29 PM
