LT230 output bearing replacement - Defender Source
Old April 21st, 2016, 12:43 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I am trying to locate a slide hammer with a 30mm adapter so I can thread it on to shaft and pull the shaft and bearing. Looked online forever, anyone know a company which supplies a threaded adapter in the US, found a few in England.
Old April 21st, 2016, 12:53 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Are you doing the front or rear output bearing? Rear you can take the whole housing off and swap on the bench which is much easier.
Old April 21st, 2016, 12:57 PM
hcdmueller
Chris Mueller
88 D-90
I just replaced mine in my driveway without any special tools. Once I got the snapring out, I just reinstalled the drive flange and lightly pryed against the case with a couple large flathead screw drivers. The whole shaft and bearing slid right out. I have changed a couple on older discos that just pulled out by hand.
If it is difficult enough to need the slide hammer and you are willing to drain your transfer case, you can remove the entire output housing and knock the shaft/bearing out from the back side.
Old April 21st, 2016, 01:05 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Just put the flange back on temporarily after removing the snap ring and use a regular slide hammer on there...
JL
Old April 21st, 2016, 01:17 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Thanks for the quick replies guys,
I was going to do both, but reading from some people they are saying that if those bearings are gone then probably the whole case may be worth rebuilding...? any opinions on this, is it worth getting a rebuilt T-case then from ashcroft
Old April 23rd, 2016, 09:06 PM
Cal's Avatar
Cal
Cal Thompson
1987/110 3 door ExMod
I'm in this same boat, so I'll be following your progress.
Old April 24th, 2016, 03:10 AM
The front is easy to get out. They tend to be the first to go. Unless you have run very low on oil for a long time the rest of the case is probably fine.
Old April 24th, 2016, 11:46 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
What is the life expectancy of the output bearings, I have 175,000 miles on mine ?
Low oil has never been an issue.
Old April 24th, 2016, 12:04 PM
Infinity. Low oil is what kills them or vibe issues from lift/unbalance shafts, bad u joints.
Old April 25th, 2016, 10:37 AM
USLandy's Avatar
USLandy
Andrew
defender 90
I decided to get the parts and just throw in the new bearings instead of doing the whole transfer case. I am moving out to Utah in 2 weeks for work and don't think I can get one in from ashcroft in time.
I'll be doing the work next week and I'll post an update.
Old April 25th, 2016, 10:57 AM
Used ones at recycling centers are the way to go
Old April 25th, 2016, 01:27 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
If you find copper chips inside the housing ...
... they are sourced inside the diff housing: the dished washers went gone bye bye!
Depending how long they are missed at their origine places the housing might be washed out too much!
Or the central shaft nut got lose or broken.
This causes a damaged outer diameter!
It makes sense to think about a new diff then.
Ashcroft has the right answer: Ashcroft Transmissions
Old April 25th, 2016, 03:25 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I hope its not that!
Old April 25th, 2016, 03:51 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I use the original M20 locknut, cut the nylock out and weld it to a matching thread for the slide hammer.
You need 2 times a 6207 bearing.
Early versions have the 6207-C3 inside. That means that there is a greater play than regular.
You don't need this version!
On the other hand, are you sure the bearings are worn?
What about the drive shaft joints? And the connecting nuts and bolts?
Sometimes the rear central M20 nut is not tight. Have a look for a drop of oil at the handbrake drum/brakeplate.
ac, lt230
Wanted - LT230 parts - diff output gear and DII front output flange oilburner Wanted 0 March 20th, 2016 08:40 PM
LT230 front output shaft bearing dsh12 Defender Technical Discussions 6 October 19th, 2014 08:29 AM
Lt230 frt output shaft bearing Uncle Douglas Defender Technical Discussions 9 December 15th, 2009 08:14 PM
Front Output Bearing landrovered Defender Technical Discussions 5 October 15th, 2007 01:56 PM
LT-230 output shaft bearing number? PTSchram Defender Technical Discussions 1 September 27th, 2007 03:15 PM
