LT230 linkage problem - Defender Source
Old January 1st, 2011, 07:56 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Here is the linkage that came with my t-case and LT77. I know there are two types out there and this is not working, I don't get enough throw to complete the shift.
Any thoughts?
Name:	cdl linkage.jpg
Old January 1st, 2011, 09:10 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
You mean, Diff lock or high & low range that you don't have enough throw?
Old January 1st, 2011, 10:19 PM
in your picture the flange that holds the shift lever on the pivot bolt for diff lock is 180 degrees out from how mine is mounted.
Which way isn't it shifting high low or diff lock ?
Old January 2nd, 2011, 10:13 AM
bcourtney's Avatar
bcourtney
Robert Courtney
I actually have tried it both ways. I have flipped the lever on the top of the t-case around as well. If I adjust the pivot bolt in or out I can get one or the other but not both.
Old January 2nd, 2011, 11:30 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I had this problem once. Take the flange off of the little switch and use plyers to grab the switch and shift it right and left. You should feel 3 clicks if I rememeber right. Click all the way to the drivers side is unlocked, middle click is still unlocked and all the way to the passenger side is locked. Flip the flange 180 degrees like Doug said and put the switch into the middle position and hook the flange to it. Move the pivot out so that it is some what snug to the throw arm.
Now from the cab see if the diff knob switches it to unlock/lock.
When I was doing it, I was getting confused as to why there was 3 positions. I kept telling myself that the middle is neutral, but I guess it isn't and is just unlock too.
Old January 3rd, 2011, 10:11 AM
bcourtney's Avatar
bcourtney
Robert Courtney
I think I have tried that but will continue. It is almost like if the stud on the linkage was facing back instead of forward it would be more straight up and down and work better. I just want to confirm this version of the linage is the one I should be using. I pulled this picture up and this one looks different. See how it is straight up and down.
Old January 4th, 2011, 07:42 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
you have the right linkage but have it all (the part that attaches to the t-case and the upright part) backwards. You may also have a worn shifter or pivot washers.
Matt Browne
Old January 5th, 2011, 12:28 AM
ini88's Avatar
ini88
Daniel Marcello
Yup, those little white plastic bushings might be worn out. There was a good site that had a video on the CDL locking. I will try to find it for you.
Old January 5th, 2011, 09:45 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Court is on vacation this week, not sure if he will have internet, I'm sure he will respond next week.
Old January 16th, 2011, 08:42 PM
bcourtney's Avatar
bcourtney
Robert Courtney
I switched this around and it still does not line up. Anyone got a picture of a complete linage?
Old January 18th, 2011, 11:56 AM
you are almost there, brother!
Old January 18th, 2011, 12:04 PM
ok, I can see that there is a difference in the placement of the center pivot. The photo I posted is a suffix L R380. I have some oddball linkage pieces floating around and may have what you need. Though it looks like if you move yours in front of the center pivot it might work?
Old January 18th, 2011, 12:06 PM
ashtrans
Dave Ashcroft
thats a R 380 diff lock lever, not a LT77 one which is why it doesn't fit !
Dave
Dave Ashcroft
Old January 18th, 2011, 12:12 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Damn, I knew we were not both crazy! My thumb is still bleeding from trying to make it work!
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Picture of what LT77 linkage looks like:
Email:
Old January 18th, 2011, 02:21 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have a bunch of old LT 77 linkeage about
legend in my own mind
Old January 18th, 2011, 03:10 PM
bcourtney's Avatar
bcourtney
Robert Courtney
That is the picture I posted up on #6 thought I had the wrong one.
Great I will PM you!
Old January 18th, 2011, 03:29 PM
ECR's Avatar
ECR
You were right. Always go with your gut.
Sorry I didn't look at this thread sooner.
LT77 and automatics use that linkage. R380s use the other.
Email:
Old January 18th, 2011, 06:37 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Was hoping to get rid of some of the old style linkeage. But I have what you need as well.
lt230
LT230 Linkage rebuild kit? bharris Defender Technical Discussions 6 March 29th, 2010 06:59 PM
D90 LT230 t-case linkage evilfij Wanted 8 April 26th, 2009 10:49 AM
LT230 locking linkage needed pcarey Wanted 2 July 23rd, 2007 01:11 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
