LT230 leaking - Defender Source
Old March 24th, 2013, 01:25 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
LT230 leaking
Does anyone know of a shop in Salt Lake City who will replace the seals on the transfer case for a reasonable price?
Since the T/C needs to come out I'm thinking of converting it to 1.4 gears. Does anyone know of a place in the U.S. mainland to buy the gears? (Yes, I know I need to research the serial number to get the correct set of 1.4 gears.)
Thanks!
Old March 24th, 2013, 01:35 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Great Basin Rovers is pretty legit.
http://www.gbrutah.com/
Old March 24th, 2013, 01:47 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Thank you! At least they are close. What have they done for you?
Old March 24th, 2013, 02:45 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
R&P?
Old March 24th, 2013, 02:50 AM
CDeWan
Clay DeWan
5.3L beastie
RP
Ring and Pinion for changing the gear ratio in your axles. I actually put in a 2003 1.2 T case from a Disco II (I thought it was an 04) I had to swap over my front and rear housing to get the Center Lock Diff to work.
I now have a taller final ratio for highway use but I wouldn't recommend it in the mountains behind a 3.9 you will be down shifting constantly.
E=GuamPilot;424042]R&P?[/QUOTE]
Old March 24th, 2013, 02:54 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Yes, sorry, I should have known R&P = ring and pinion.
I'm pretty sure my D90 came with a 1.6 TC. I swapped in a TC from a 98 Disco and now the gearing is way too tall. Need to hit that middle spot with a 1.4.
lt230
LT230 Transfer Case jimmy salmon For Sale - Parts 2 December 17th, 2004 07:19 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
underdrive for lt230 boxerhips Wanted 1 October 9th, 2003 10:00 PM
