LT230 Input gear again! - Defender Source
Old June 16th, 2005, 08:55 PM
Well about a mile from home and all of the sudden I get some loud groaning coming from right under the tuffy box, so I take it home put the T-case in neutral and the tranns in gear. I get the same noise and it gets worse as I go faster doesn't matter what gear the tranns is in. So I pulled the input gear, well check out the pictures. I have a set of bearings in hand that I can throw on the input gear, but I'm kinda afraid that the other bearings in the case might be in bad shape. So should I replace the bearings and try driving it? Or with this kind of wear should I just pull it out? If anyone would like to see higher res pics I have them.
Thanks guys
ID:	3312   Click image for larger version
Old June 16th, 2005, 09:15 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
dosn't look good Mike pic 3
Old June 16th, 2005, 09:27 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Looks like some excessive wear near the edge of the teeth from root to tip. It's been a while since I've pulled that gear out but I think the cover plate basically sets the preload on the gear. It appears that there is some gear movement...alot actually. Can you move any of the other gears on the mainshaft? Maybe a shim has disintigrated and one is "floating". From the pics I can't see any obvious bearing damage, is there any debrish in the bottom of the case?
Tis
Old June 16th, 2005, 09:32 PM
Well I just ran out and checked, the other gear (big one in the case) flops around quiet a bit, maybe an inch or so. Looks like I'm droping the case
Old June 16th, 2005, 11:42 PM
Well did you replace the crush sleeve when rebuilding it?
Are any of the bearings fragged?
In the words of mike m. "What did you do dude?"
Old June 17th, 2005, 08:49 AM
I bought the case about 1.5 years ago from TN TRL. But when I last drained the fluid from it it came out in chunks and smelled like swamp, so I pulled the inspection plate and pulled out the input gear and cleaned everything out. Then I filled and drained the gear oil 3 or 4 times to get the rest out. This was all in the last 2 weeks. I think I need to pull the inspection plate off and see what's up inside, but the gear that came loose (the intermediate gears I think) looks like it came loose at the back side of the case. I'm going to look at the manual for the T-case and see what I don't have that I would need to rebuild it in the way of tools.
OK, Can I save mysefl a bunch of work and get the intermidiate gear out without haveing to take the T-case out? I still have too see what damage is done but just trying to figure some things out.
Old June 17th, 2005, 02:43 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Mike,
You have to take the t-case out to remove the intermediate shaft.
Rob
Old June 17th, 2005, 02:48 PM
I wasn;t sure if I could drive out the shaft in place or not, oh well just a few hours more work.
Thanks All!
Old June 17th, 2005, 04:40 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Mike, just a request (and I'm sure you'll do it anyway) but I was wondering if you could put details as to how you rebuild the TC as you go along. I have a TC rebuild ahead of me in the near future and I will need to use all the help I can get!
Thanks!
Old June 17th, 2005, 07:07 PM
I'll take pics and list what I do, I may not have to rebuild the hole thing but we'll see. Almost got it out tonight, but it started pooring.
Old June 18th, 2005, 02:53 PM
redrover
Guest
Posts: n/a
Mike you should drop some of those ascroft crawler gears in there during the rebuild. I put the maxi -crawler gears in when I did my case. Love em. JP
Old June 18th, 2005, 04:11 PM
That would be nice but with the current exchange rate they are a bit of $$$$$
But here is what I have found, looks like the bearing disintegrated, and caused the wear on everything. Looks like I need to do a full rebuild just to clean it all out, then maybe replace a few of the chipped gears/cogs. What does everyone think of the wear on the inside of the case where the bearing was? And is Ascroft the only place to order parts? I know RDS has a rebuild kit but what about replacing gears/cogs?
Thanks!
ID:	3320   Click image for larger version
Old June 18th, 2005, 04:37 PM
cbass's Avatar
cbass
Bradlee Duncan
Dang Mike, that's too bad. I am not familiar enough with the workings of a t-case to give you any advice yet. But....
I was wondering from you JP, where could I get some more info on the crawler gears (maxi or ashcroft) for the LT-230??
Thanks!
Old June 18th, 2005, 04:41 PM
http://www.defendersource.com/forum/...ead.php?t=5630
Old June 18th, 2005, 05:46 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
Hi Mike. I'm sorry to hear about your T-case trouble. Didn't Great Basin Rovers have the T-case gears as well? They are expensive, but since you have to spend some $$ anyway, check to see if the difference would be worth it for you. Good luck and keep us posted on your progress.
Old June 18th, 2005, 09:13 PM
Hose it out with brake clean and a magnet, replace the bearing and any other bearings that look suspect and fill with oil and it should be ok.
Make sure to check both output bearings to see that they are ok.
Alternatively you could ship me your diff and I could make the one I have here whole for not too much cash.
Or even better I could ship you the core I have here, sans diff, and you can put yours back together for really cheap.
I have done a few for people on the board and in spite of less than ideal cores and using used parts to fix them I have no complaints--of course price reflected condition.
Ron
evilfij at yahoo dot com
Old June 19th, 2005, 10:34 AM
Stephen, I have sent out some e-mails looking into those options
Ron Thanks! Before this happened I had cleaned it out thought the inspection plate with break cleaner, but I think the bearing was already gone by then. The plan at a minimum was to buy the rebuild kit RDS sells and replace all the seals and bearings and clean it all out. I don't mind rebuilding it I just don't want to do it twice, and with the wear on the input gear, the chipped teeth on the intermediate gear and the damage done to the case by the bad bearing on the intermediate shaft I'm not sure. I can replace the gears easy enough, but the damage to the case is what worries me, I can just clean it up with a file, but will the crush bushing take up the slack for the ground down case?
I'm going to wait for some more input from a few emails I sent out and then go from there.
Old June 19th, 2005, 06:45 PM
Even if you are doing a full rebuild you will want to buy mine because the gears in yours have issues. This way you can use my case as well. If you buy new gears you are way over the cost of a reman.
lt230
200Tdi and LT230 Gear Ratio Question newfD90 Defender Technical Discussions 33 June 1st, 2016 02:30 PM
Tips on Swapping out the T-Case input Gear? LRNAD90 Defender Technical Discussions 2 April 23rd, 2009 05:14 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
