Lt230 frt output shaft bearing - Defender Source
Old August 3rd, 2009, 06:39 PM
any pointers on replacing the front output shaft bearing on an lt230 ? Is it as straight forward as removing the nut/flange/ seal, pull the bearing and tap in a new one ? Mine is screaming but just limped 260 miles home.
Old August 3rd, 2009, 09:46 PM
http://www.discoweb.org/tcasebearing/index.htm
Old August 3rd, 2009, 09:56 PM
cool, but why not just use a seal puller to get the seal out?
Originally Posted by evilfij
Old August 3rd, 2009, 10:23 PM
Have you met Brian Jackson?
Old August 4th, 2009, 10:18 AM
Thanks Ron.
Old December 6th, 2009, 02:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Doug,
how did it go?
I'm needing to do this soon, any pointers?
Old December 6th, 2009, 03:08 PM
x2, mine has a little play, Ive been told this is "common" issue with these trucks. I know one guy that did this he said it was horrible, and the new bearing still had play in it.
Old December 6th, 2009, 10:40 PM
Well I had a random scream that usually started up after being off road. It turned out to be the steel plate under the drive shaft yoke that is meant to keep trash away from the seal itself. The plate was spinning when mired up and the scream was the steel plate grinding on the aluminum tcase housing. The bearing and seal were in great condition.
Old December 13th, 2009, 03:50 AM
D90user's Avatar
D90user
steve
I just tried doing this and there is no conceivable way that my front output bearing would come out with hooks as described above.
I have been trying this way:
http://www.aulro.com/afvb/technical-...oil-seals.html
But no luck yet. Any advice would be appreciated.
Old December 15th, 2009, 08:14 PM
D90user's Avatar
D90user
steve
finally got this done.
The method in the above link did not work for me at all. The main reason was that the inner race was very tight on the shaft and it would just pull the bolts out.
What did work was using the bolts as described above, and a slide hammer.
If I were to do it again I would use a slide hammer on the big nut on the shaft (after taking the seal and c clip out of course) and just pull the shaft and bearing out together.
Some may just come out with no trouble... mine did not.
lt230
LT-230 output shaft bearing number? PTSchram Defender Technical Discussions 1 September 27th, 2007 03:15 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
Auto trans output shaft extension needed JCRover4x4 Wanted 1 June 15th, 2004 10:10 PM
