LT230 front output shaft noise - Defender Source
Old March 30th, 2011, 05:56 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Im experiencing a bunch of audible slop in the front output shaft of the transfer case (LT230). Not only can I move it laterally with my hand, it produces a very loud metallic clunking sound. It has been this way for sometime, but became painfully noticeable when running on the front axle when the rear drive shaft u-joint failed. Consequently, I believe the problem is isolated to the front output shaft. What would be the most common cause of this? Would the repair be involved?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old March 30th, 2011, 06:05 PM
Bad seal --> low oil --> output bearing shot.
Mine has the same issue right now. I am going to swap out the whole case, but you may wish to try this repair.
http://www.discoweb.org/tcasebearing/index.htm
Ron
Old March 30th, 2011, 07:24 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I'd change the box out, if the front is bad, the rear is not far behind...I just got a used lt230 shipped for $225.00
Old March 30th, 2011, 09:09 PM
dsh12
Daniel Hayes
...shipped from who? Is it an earlier or later model (what is the model letter?)?
Dan
Old March 30th, 2011, 09:38 PM
Ive taken extremely good care of my truck for about 50k. It had a loose front output for maybe 15k, I was told no sweat. I know in one case a person replaced the bearing and still had play. The front output in my classic is sloppy, unknown mileage on the case but it doesnt have much slop and the input looked good when I installed it.
Did you replace all the ujoints? Do you know if you have the updated input spline in the t-case? Have you checked the fluid? Ive found that a half quart of lucas and mobil 1 does a good job if you over fill....
Im sure ill blow my transfer case.
FWIW
Old March 30th, 2011, 10:15 PM
jhhorse
joe heins
1995 defender 90
My T-case in my 95 d-90 had that same slop, was also getting very noisy, I thought this was "normal" for a while but it got worse so I put in a used LT230Q from a 98 disco and the difference was night and day. New box has no play in either front or back and is silent compared to old one. There are plenty of these boxes around, I would just get one and replace your current T-case
Old March 30th, 2011, 10:32 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Drillbit...aka Marty Powell over on Dweb...his number is 270 576 7922
He's in Kentucky, so it should be a little cheaper for shipping, but the case maybe a little more expensive as you'll need a tcase from a D1 (need the vss on the rear output housing), not a D2 (doesn't have the vss, and he does have ones with cdl). He gets a little more for the D1 cases.
I didn't get the model number, as I really don't care if it's quieter, it's going in my 110 and I couldn't tell the difference anyways.
tell him I told you to call
Old March 31st, 2011, 07:22 PM
dsh12
Daniel Hayes
Im running expensive synthetic in the LT230; this maybe why it is still working. This can get expensive with the output shaft slopping around as it requires a bit of topping off. Replacing it with a used box seems like the way to go.
A few questions:
- a 98 Disco is considered a D1?
- what is vss and cdl?
- jhhorse, what did your LT230Q cost?
Dan
Old April 1st, 2011, 06:00 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
98 is a d1
Vss is the speedo connection on rear output housing
Cdl is the center lock on the tcase. Some d2 tcases don't have the nipple
Old April 1st, 2011, 06:07 PM
is there anyway to get the VSS to work with the later DII transfer case
Old April 1st, 2011, 06:11 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Originally Posted by evilfij View Post
Good info there. I did mine a while back and I could not get it out with a hook... not a chance. A slide hammer did the trick. I did it still in the truck and it is easier than taking the case out.
Old April 2nd, 2011, 02:23 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Why don't you try and tighten the nut first!!!
Old April 2nd, 2011, 03:04 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
simple answer is no, couple of options, use the rear output housing from your existing case, or re-build the your original one, it will bolt up directly
Old April 2nd, 2011, 04:26 PM
jhhorse
joe heins
1995 defender 90
Daniel, Had my local mechanic source the T-case, after he inspected and resealed the box, (he changed some bearings) the total was 450 for the T-case, the D1 it came out of was wrecked with about 65K on it. The noise difference is remarkable, truck much smoother, got rid of a lot of vibration and clunks. Well worth it, IMO.
lt230
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
