LT230 front output shaft bearing - Defender Source
Old October 15th, 2014, 11:31 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Has anyone changed the front output shaft bearing (race and seal) on a LT230 WITHOUT removing the the T-case?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 15th, 2014, 11:41 PM
never tried but seems like it should be doable. Worst case pull the floor on that side for better access
Old October 15th, 2014, 11:44 PM
Right here WITH photo's too:
http://www.landyzone.co.uk/lz/f41/tr...wal-81771.html
Buster has a bunch of DIY posts and his narratives are pretty funny to read.
busters-photo-tour-landrover-repairs
Old October 18th, 2014, 09:58 PM
dsh12
Daniel Hayes
The Buster photo tour was excellent. I'm a little confused about the replacement bearing. Buster is showing a ball bearing for the front shaft. The following link seems to show a roller?
http://www.partsgeek.com/catalog/199...t_bearing.html
British Pacific is showing the ball bearing:
http://www.roverparts.com/Parts/STC1130
Dan
Old October 18th, 2014, 10:11 PM
If its a daily driver order one of each and ship back the one that you don't need. If it's a third vehicle pull the bearing out and get what looks correct.......... or send a picture to Zack at Rovers North and he will hook you up with EXACTLY what you need.
Old October 18th, 2014, 11:56 PM
There is a how to on discoweb.
Old October 19th, 2014, 08:29 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The shafts are supported by ball bearings.
The taper roler bearings hold the diff inside the housings.
lt230
LT230 front output shaft noise dsh12 Defender Technical Discussions 13 April 2nd, 2011 04:26 PM
Front output housing issue, can I drive with messed up bearing? Help ASAP please evilfij Defender Technical Discussions 13 March 10th, 2011 09:29 PM
Lt230 frt output shaft bearing Uncle Douglas Defender Technical Discussions 9 December 15th, 2009 08:14 PM
Front Output Bearing landrovered Defender Technical Discussions 5 October 15th, 2007 01:56 PM
LT-230 output shaft bearing number? PTSchram Defender Technical Discussions 1 September 27th, 2007 03:15 PM
