LT230 Fluid Recommendations - Defender Source
Old August 26th, 2012, 02:15 PM
lcarter
Luther Carter
1995 Defender 90
Would Redline 75W90 Gear Oil be suitable? How many quarts needed?
Old August 26th, 2012, 02:22 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
If yours is leaking like most lt230s then get cheaper oil and keep topping it off now and again.
If yours is sealed up and never leaks go with a better quality 75-90w.
I think it take around 2.5l. Fill it till it starts to come out the full hole. Also undo the fill hole first before the drain. Sucks to drain all the oil and not be able to refill it.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 26th, 2012, 07:07 PM
Search
Old August 26th, 2012, 08:38 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Just make sure its API GL5 and NOT GL4. 80W90 non synthetic or 75W90 Synth, but either way must be API GL5 for TC and diffs.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old August 27th, 2012, 10:34 PM
lcarter
Luther Carter
1995 Defender 90
Old August 28th, 2012, 12:49 AM
grnrvrs's Avatar
grnrvrs
Paul
88
I'm curious about your source.
Per LR GL4 or GL5 in the LT230T/Q/SE, check out p6 in this PDF.
http://file.seekpart.com/keywordpdf/...3228267973.pdf
Edit: GL5 has a reputation for harsh wear of yellow metals, while GL4 plays nice with brass, bronze and copper. In a series transmission and transfer case, which contain yellow metals, it is GL4 not GL5 that is required. For an LT230 LR specs either.
1970 SIIA 88, Sold
Old August 28th, 2012, 06:01 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yup, GL4 is fine. It's harder to find though. Rumor has it that newer GL5 formulations don't attack yellow metal like it did when it was first on the market. I've no idea to the truth of the rumor however.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 31st, 2012, 02:26 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Most decent GL5's use a buffered sulphur EP additive which is non-reactive with most yellow metals.
I've heard of supposed corrosion with some synchro hubs, but if in doubt and a TDS/PDS is available, look for the copper corrosion numbers.
1a or 1b mean no discolouration/non-reactive.
lt230
milk chocolate brown LT230 fluid cdb Defender Technical Discussions 6 April 25th, 2012 11:02 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
