LT230 education help - Page 3 - Defender Source
Old December 7th, 2015, 02:06 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by Red90 View Post
Unless someone has dynoed one, then nobody know for sure. It is ridiculous (in my mind) that anyone would be tuning an engine to double stock power without involving a dyno.
So what crazy levels of boost are being used to get to that amount of power?
So we know from the specs that the C-111 had an OM617 that produced 230HP in 1978.
This was believed to be with with 6.5mm plungers and a tuned stock M-IP that had an internal ALDA.
Fast forward to 2015 and Goran is building external ALDA IPs for the OM617, OM606, and so on.
Granted the OM606 is a different engine with the same displacement as the OM617 and with a very similar IP.
If it can produce over 500 HP with 8mm plungers an external ALDA and about 30 PSI boost, don't you think it's reasonable that the OM617 can produce 250HP with 7.5mm plungers at 15 PSI boost?
RDavisinVA
Old December 7th, 2015, 02:19 PM
Neither of those boost figures make sense. You double the horsepower, you must double the airflow as a minimum. It is simple math. You can't just stuff fuel in and make power. There needs to be an equivalent increase in air flow. I still see no proof of these horsepower claims. I did go look and the best dyno I saw was around 150 hp.
Old December 7th, 2015, 02:43 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Are you aware that the stock boost on the US spec OM617 is like 6-7 PSI?
When a dyno page at 250 HP or better shows up and it eventually will as Goran sells IPs, what will you say then?
Hell you could use the 1978 setup and add propane boost and get 250 without Goran's IP.
RDavisinVA
Old December 7th, 2015, 02:51 PM
I'm totally lost regarding what robert and john are arguing about.
Robert posted some dyno figures for an OM606 which has ~140 NA bhp running at >35psi boost. He also mentions some hot-rod racing OM617 engines which has ~80 NA bhp but boosted to 300hp, which could be done via some big turbos running >30psi and revving the engine 1000-1500rpm above the standard redline.
None of these figures sound unreasonable, especially in engines that last a couple of races and have to be rebuilt often.
I think John was originally suspicious of the OP's claimed "250hp" number and wanted proof. Robert is saying "it's possible", but just because it's possible doesn't prove that the OP actually has a 250hp OM617 engine.
The OP just told John to pound sand - I guess that discussion is over
Old December 7th, 2015, 03:00 PM
Okay. 7 psi is 22 psi absolute. Doubling the volume is 44 psi absolute or 29 psi boost at the same IAT. I'm sure with more engine speed and overfuelling this can be a bit lower, but not 15 psi.
I would love to see the dynos and some real tech.
Old December 7th, 2015, 03:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I think it's narrow minded to say 250 HP is BS, when 230 was achieved in 1978 without Goran's high performance pump.
Gorans M-IP with 7.5mm plungers external ALDA and 15-20 PSI boost with a full width intercooler and a W-115 inlet manifold can do 250HP no question.
Yes 250 HP out of a US spec OM617 with the MW-IP with 5.5mm plungers and internal ALDA with 5-7 PSI boost without an intercooler is BS, agreed.
RDavisinVA
Old December 7th, 2015, 03:11 PM
You say 230 hp was achieved in 1978. All I ask is some sort of proof.... A link to something, somewhere where someone may have possibly witnessed a measurement of horsepower in this ballpark.
I did spend an hour looking around on the internet and could not find anything other than people saying going anywhere near this in a 617 and your engine will blow up in short order. I found some dynos, but nothing over 150.
Old December 7th, 2015, 03:12 PM
ezzzzzzz
Mark Garrenton
Who?
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old December 7th, 2015, 03:17 PM
I'm not being narrow minded. All we have is you stating numbers. You have obviously never run a truck on a dyno. The OP have obviously not run his truck on a dyno. Personally, I don't just blindly accept power claims. Show me the money...
You guys should be running dynos just to make sure you are managing and controlling peak torque. That nice new and expensive Land Rover gearbox will blow up if you have too much.
Old December 7th, 2015, 03:18 PM
Originally Posted by ezzzzzzz View Post
Who?
Please expand on the question....
Old December 7th, 2015, 03:28 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
John:
You don't know me, so how can you say I have never run on a dyno?
This is purely another example of a narrow minded statement.
RDavisinVA
Old December 7th, 2015, 03:45 PM
John:
I say that because I asked to see a dyno and if you had run one, I assume you would show it to me or, in the least say "I ran an OM617 in 1922 on the dyno and it had 200 whp, but I don't have a copy of the printout". I'm sorry if I was wrong. I was just putting 1 and 1 together.
Old December 7th, 2015, 03:46 PM
scrubs
henery
1974
HP by elements
Old December 7th, 2015, 03:57 PM
Originally Posted by scrubs View Post
Okay, let me ask it this way to avoid further raising Robert's blood pressure....
What boost are you running and what turbo?
What is your top speed and what is the cause of the limit? I can pretty accurately determine wheel hp based on your top speed if it is engine limited.
Old December 7th, 2015, 04:13 PM
scrubs
henery
1974
Welp, .......at this time really don't believe anything put to you would matter.......true to your signature. ....."pissing people off".......
I've put alot of time and resources into my build & I'm dam proud of it, so to try n explain to a doubter who just limes to piss people off......well you get the idea. .....
You are a very valuable asset to this community n thank you for the lt230 information
Old December 7th, 2015, 04:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you don't read the posts, then you overlook the proof...
The link was provided back in post 18, 38 posts ago!
LMAO.
RDavisinVA
Old December 7th, 2015, 04:29 PM
Sorry. I'm not trying to piss anyone off. I just like having science and facts. I just wanted some facts backing up such big power in an old and small diesel.
Are you not interested in what power you are actually making? I'm sure others would be as they would love a 250 hp diesel option. Personally, I think you guys are a bit too trusting in numbers that people throw around, but that is just me apparently.
For what it is worth, from my calcs, which seem to match well with other known engine outputs...a stock height and tired Defender with 250 engine hp should be able to do around 115 mph with the right gearing. This uses a number of 159 wheel hp (15% drivetrain loss). Not sure anyone wants to test 115 mph in a Defender but you would still be accelerating well at 90.
Old December 7th, 2015, 04:33 PM
LMAO.
With all due respect Robert. You added the link during an edit later on. It was not there when I read your post originally.
Old December 7th, 2015, 04:37 PM
Anyone remember why the OP posted in the first place?
Old December 7th, 2015, 04:40 PM
scrubs
henery
1974
You gotta do what you've done for your LR knowledge, which is excellent, go wherever they run these setups,
It's all there n very easily accomplished
I posted looking for LT230 information
lt230
A quick education on Rostyle wheels Gas_Donkey Misc. Chit-Chat 53 January 2nd, 2017 04:03 PM
lt230 tcase mount rhs (disco lt230) Cajun Wanted 8 October 14th, 2015 06:30 PM
RUST - Education Jonesy Defender Technical Discussions 3 July 24th, 2015 11:24 AM
An Education on Boost Wheels... Holiday Defender Technical Discussions 2 January 17th, 2011 11:11 AM
underdrive for lt230 boxerhips Wanted 1 October 9th, 2003 10:00 PM
