LT230 - difference between auto and manual? - Defender Source
Old February 2nd, 2008, 05:49 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I need a new TC and found one from a Disco I, but the guy said it's different between a manual and automatic transmission install. I have not heard this before & can't find any reference to that.. true or false? Can I use it?
Old February 2nd, 2008, 06:35 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Just saw this post so you probably won't need one of my spares that I offered in the other thread. One of the LT230's I have is out of a Disco, and I had to swap over the speedo housing from my old LT230 so that I could connect the speedo. Other than that there were some extra switches/sensors that aren't used. Haven't heard of a difference related to manual vs auto trans.
Old February 3rd, 2008, 01:25 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Its the same t-case just a few sensors that you don't need to hook up. I have a disco unit in my series project truck.
Legend in My Own Mind.
Old February 8th, 2008, 11:17 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Yeah, I just put a Disco I TC in our defender too. As was said above, you'll likely need to swap the speedo sensor from a D-90 TC. You'll also need to remove the shift lock solenoid. It's right on top of the TC and you remove the four bolts holding it (it has a wire coming out of it) and remove the solenoid from inside the housing (the same as permanently releasing the solenoid) and put the housing back on with some silicon sealant to plug up the hole left from the wires. Works great!
lt230, manual
WTT Auto for Manual mpsteil Wanted 8 June 16th, 2009 09:31 AM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Hi-Lo-CDL shifter, Auto vs Manual? PCRover Defender Technical Discussions 2 March 17th, 2008 12:42 AM
Manual To Auto Conversion willtillery Defender Technical Discussions 2 September 22nd, 2004 10:12 PM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
