Lt230 - Defender Source
Old November 15th, 2011, 08:51 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Lt230
I have a NAS D90 driveline that I am transplanting into an 83 One Ten. The transfer case has spun a bearing and torn up the main case.
I have a bunch of D2 Tcases sitting around, and was considering just using one of those cases to rebuild it using the original 90 230 internals.
Anybody confirm that the cases are the same?
thanks!
Email is
Same place, new dogs.
Old November 15th, 2011, 11:03 AM
can you document the change over if you do it with lots of pics? I'd like to see what's involved with an LT230 rebuild, particular in switching ratios.
Old November 15th, 2011, 11:14 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Come on Mark, don't be skeered, those two articles I sent you are all you need!
Semper Fi!
Old November 15th, 2011, 11:16 AM
The tail housing is different, but the main case is the same other than the solinoid hole and one sensor hole that I am aware of.
Old November 15th, 2011, 11:22 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I put a disco 1 lt230 with a d2 parking brake assembly on an '83 110. the only fiddly part was working out the parking brake cable (it's short for a RHD truck) and the speedo cable input. Otherwise it bolts right up.
Old November 15th, 2011, 11:27 AM
Also, if it were me, I would keep the DII internals and just swap the tail housing assuming that the DII case is the one with the diff lock provision.
Old November 16th, 2011, 04:08 PM
ashtrans
Dave Ashcroft
here you go :
http://www.ashcroft-transmissions.co...d&productId=44
Dave
Dave Ashcroft
Old November 16th, 2011, 04:16 PM
I'll be honest...I is a little skeered!
lt230
Lt230 Refit Nil Defender Technical Discussions 5 December 2nd, 2004 12:36 PM
LT230 out of 94 D90 80k $350 evilfij For Sale - Parts 5 December 1st, 2004 05:33 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
3rd Members with 4.75/ARB's and LT230 billnsandi For Sale - Parts 0 January 26th, 2004 11:29 PM
