LT230 1.2 or 1.4 - Defender Source
Old April 16th, 2014, 02:27 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
LT230 1.2 or 1.4
God I havent posted for the longest time ...
I know this has been beaten down before but just cant seem to find it.
I am ordering a R380 mated to a lt230 from Ashcroft with all the bells and whistle and wondering if I should go with 1.2 or 1.4 gearing.
The truck is a tweaked large intercooler 200tdi 110 and runs on 33" mud terrain.
Have to give an answer tomorrow morning ....
Thanks everyone !
Pat
Kirk Lazarus, Tropic Thunder
Old April 16th, 2014, 02:32 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
1.4 seems to be the consensus.
Old April 16th, 2014, 02:56 PM
roverhaggis's Avatar
roverhaggis
Rick
1964 109 5-door
2 cents
1.4 works great w/200TDI, I'm using LT77S.
LT77S ratios
1st 3.58:1
2nd - 2.30:1
3rd - 1.51:1
4th - 1:1
5th - 0.83:1
reverse - 3.70:1
R380 Diesel
1st - 3.69:1
2nd - 2.13:1
3rd - 1.40:1
4th - 1:1
5th - 0.77:1
Reverse 3.54:1
R380 Gas V8
1st - 3.32:1
2nd - 2.13:1
3rd - 1.40:1
4th - 1:1
5th - 0.73:1
Reverse 3.54:1
Roverhaggis
Old April 16th, 2014, 03:00 PM
Did you use the ratio calculator tool on the Ashcroft site? For me, the 1.2 seemed a bit better. You'll be running taller tires, so the 1.4 might be the right thing.
Old April 16th, 2014, 03:04 PM
LT77S ratios
1st 3.58:1
2nd - 2.30:1
3rd - 1.51:1
4th - 1:1
5th - 0.83:1
reverse - 3.70:1
That is not correct. The LT77S version supplied with the 200TDi has the same ratios as the diesel R380. The ratios quoted above are for the LT77 from before the TDI.
http://www.red90.ca/rovers/gears.html
My suggestion...if ordering new boxes is to order the R380 with the 0.732 5th gear option and use the 1.4 t. case. With a 1.2, 1st can be a bit high with a loaded 110. Also make sure you get the one piece cross shaft for the center differential.
Old April 16th, 2014, 03:08 PM
I have a 1.2, but I have a 2.8. If I had a tdi, I would go with a 1.4. Red offers sound advice.
Mark Kellgren
KM4BOR
Old April 16th, 2014, 03:19 PM
roverhaggis
Rick
1964 109 5-door
Thanks for the link Red90
I stand corrected. These numbers must have been from the previous LT77.
Thanks for the link Red90.
I am using the late LT77S and 1.4 LT230. It works well with the 200TDI, LWB with 34" tires and 3.54 diffs.
Roverhaggis
Old April 16th, 2014, 03:25 PM
Retrofit's Avatar
Retrofit
Pat
Thanks !
Sounds like the 1.4 with the 5th gear mod will be ordered in the next day or so ... as per Red90
Always a pleasure posting on this forum !!!
Thanks !
Pat
Old April 16th, 2014, 04:11 PM
This rpm versus speed you end up with.
Code:
High Table
Speed/Gear	First	Second	Third	Fourth	Fifth
10 KPH	1167	674	442	316	231
20 KPH	2334	1348	883	632	463
30 KPH	3501	2022	1325	948	694
40 KPH	4668	2696	1766	1264	925
50 KPH	5835	3369	2208	1580	1157
60 KPH	7002	4043	2649	1896	1388
70 KPH	8169	4717	3091	2213	1620
80 KPH	9336	5391	3532	2529	1851
90 KPH	10503	6065	3974	2845	2082
100 KPH	11670	6739	4416	3161	2314
110 KPH	12837	7413	4857	3477	2545
120 KPH	14004	8087	5299	3793	2776
130 KPH	15170	8760	5740	4109	3008
140 KPH	16337	9434	6182	4425	3239
lt230
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
3rd Members with 4.75/ARB's and LT230 billnsandi For Sale - Parts 0 January 26th, 2004 11:29 PM
underdrive for lt230 boxerhips Wanted 1 October 9th, 2003 10:00 PM
