LT 95 Starter - Defender Source
Old January 6th, 2014, 04:44 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
LT 95 Starter
Is there any difference in the starter for the manual trans LT95 and later ZF transmissions. Not sure if its just the cold or if my starter might be on the way out. I have a few newer styles in the garage I think. It's to cold to pull it and see if they are the same.
Unknown Author
716-898-8153
Old January 6th, 2014, 05:09 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Early V8s had either the 4 spd (LT95) or 5 spd (LT85). The starter depends upon the engine not the transmission. My parts book lists RTC5228E as the starter for an early V8 regardless of transmission.
1970 SIIA 88, Sold
Old January 6th, 2014, 05:24 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
So it sounds like it is a different starter than the later RRC starter with the ZF trans.
Unknown Author
716-898-8153
Old January 6th, 2014, 05:45 PM
grnrvrs's Avatar
grnrvrs
Paul
88
You would have to chase down the part numbers to see what superseded RTC5228E to see if your later V8 starter is suitable.
1970 SIIA 88, Sold
Old January 6th, 2014, 06:35 PM
same. superceded to rtc6061n
Old January 6th, 2014, 07:01 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
So they will interchange, awesome thanks Doug and Paul!
Unknown Author
716-898-8153
95, start, starter
LT 95 problems Jackd Defender Technical Discussions 10 March 2nd, 2014 01:30 PM
LT 95 Diff Lock ArmyRover Defender Technical Discussions 4 December 29th, 2013 07:17 PM
need an LT 95 front drive shaft Uncle Douglas Wanted 4 June 2nd, 2008 09:41 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
