LT 95 Diff Lock - Defender Source
Old December 29th, 2013, 06:04 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
LT 95 Diff Lock
So I tried to engage my diff lock and no light on the dash and I didn't hear or feel anything happen in the truck.
I know it's a vacuum operated switch, where do the vacuum lines run to and from on it. I'm not seeing any that run towards the transmission area. So I'm assuming the PO pulled the line or it fell off.
Unknown Author
716-898-8153
Old December 29th, 2013, 06:17 PM
grnrvrs's Avatar
grnrvrs
Paul
88
On my rig, a vac line runs frm the vac pump to the power brake booster and then runs from a port on the booster to the switch. The switch has a couple vac lines that run to the vac switch on the front output.
1970 SIIA 88, Sold
Old December 29th, 2013, 06:21 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
So I'm guessing that from the switch to the pod should be a vacuum line, and from the pod to the engine should be a line as well?
Unknown Author
716-898-8153
Old December 29th, 2013, 06:49 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Engine vac source to switch to diff lock pod.
1970 SIIA 88, Sold
Old December 29th, 2013, 07:17 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Thanks Paul, I appreciate that I would have hooked it up ass backwards
Unknown Author
716-898-8153
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Defender TD5 diff Lock light Padraig10 Defender Technical Discussions 5 December 12th, 2013 01:08 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
4 Wheel / Diff Lock hamiamham Defender Technical Discussions 4 August 7th, 2007 08:50 PM
Overheating/ Diff Lock question icurnmedic Defender Technical Discussions 14 June 27th, 2006 06:06 PM
