LT 77 Drain Plug Stuck - Defender Source
Old May 16th, 2014, 06:26 PM
richord
Richard Ordowich
1987/D90
I tried to remove the transmission drain plug with a wrench but is will not turn. I was able to remove the filler plug and the strainer plug.
Any ideas on how to remove the drain plug?
Old May 16th, 2014, 06:30 PM
At least you did it in the proper order. You could have removed the drain plug and not be able to remove the filler plug.
Have you tried spraying some penetrating oil on the plug threads or hit it with an electric heat gun for a bit?
Old May 16th, 2014, 06:37 PM
richord
Richard Ordowich
1987/D90
I will try the penetrating oil. I was thinking of heating it with plumbing torch but leery about an open flame. Thanks for the suggestion of the great gun.
Old May 16th, 2014, 06:50 PM
I don't think a torch would be a good idea. Have you tried hitting the wrench with a mallet or using your foot (assuming you are doing this on the ground) to push the wrench?
Old May 16th, 2014, 07:21 PM
richord
Richard Ordowich
1987/D90
I tried hitting the wrench with a mallet but it won't budge.
I'm worried about damaging the head on the plug.
Old May 17th, 2014, 10:24 AM
I've been down this road on my truck, get a bigger wrench or double up on open ended wrenches. Have another bowl of wheaties and watch those knuckles . Someone before you likely didn't replace the copper washer on the drain plug, ask me how I know
Old May 17th, 2014, 11:05 AM
I highly doubt that will happen unless you are using the incorrect sized wrench.
Old May 17th, 2014, 05:18 PM
I tried to remove the transmission drain plug with a wrench but is will not turn. I was able to remove the filler plug and the strainer plug. Any ideas on how to remove the drain plug?
You need more cowbell.
Old May 17th, 2014, 05:23 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
It is time for a Mityvac. One of the best shop tools around.
Old May 17th, 2014, 07:13 PM
Not for a gearbox. You want to drain it and see if any heavy bigger stuff comes out.
Put the closed end of a good wrench or a 6 point socket and hit it with a big hammer.
Old May 18th, 2014, 07:57 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I was in your situation last week. I ended up going to Home Depot and picking up a piece of iron pipe to use for leverage. Still took some patience but eventually worked. Wear gloves.
Clay
Old May 18th, 2014, 08:47 AM
richord
Richard Ordowich
1987/D90
Thanks for the words of advice. I will attempt the penetrating oil, heat gun a better wrench and leverage while wearing gloves. Since I did not create this problem (I just bought this truck a few months ago), I will let fly numerous curse words for the previous owner or mechanic who put the plug in while trying again.
Are there any particular incantations that I should use when working on my Land Rover?
Old May 18th, 2014, 09:10 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yes, 6 pt .
Also, try to tighten and loosen.
The incantations cannot be printed on a public forum...
Rent my
Old May 18th, 2014, 09:36 AM
If those boxes have crush washers get a fresh one. It's probably time.
Old May 18th, 2014, 10:08 AM
l.a.rover
handy andy
73 Land Rover 88 Lightweight
Use a ....
use a breaker bar! That will provide with the necessary leverage ... Good luck!
drain, drain plug
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Wading plug and drain hole? T.U. Defender Technical Discussions 4 April 6th, 2010 03:48 PM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
