LT 230 rear housing swap help - Defender Source
Old December 25th, 2015, 02:18 PM
scrubs
henery
1974
Swapping a ex mod 1.6 to a discovery 1 1.2, the hand brake and the speedometer input are different, speedometer have figured out I think tho wondering what problems would be encountered if the rear housings were just swapped?
The 1.2 tcase begins with 28d if it helps,
Or can the hand brake assembly be swapped?
Old December 25th, 2015, 06:26 PM
xmod handbrake linkages are different in that they require additional drilling and tapping to utilize the linkage on a civy tcase. The shift linkage is also different if memory serves....sorry many drams of scotch today...
I wouldn't bother with swapping housings, drilling and tapping cast aluminum is pretty easy.
Old December 25th, 2015, 06:28 PM
Move the hand brake over. You need to drill and tapa couple of spots for the cable bracket.
Old December 25th, 2015, 07:51 PM
scrubs
henery
1974
Thanks for replys, it's a LHD, can drill n tap for hand brake bracket tho the newer 1.2 has the cable assembly running out the brake drum towards the left side the 1.6 drum has the cable going out the right side.
Old December 25th, 2015, 08:37 PM
you will need to swap the entire parking brake assembly backing plate included. Half an hours work with both out of the truck.
Old December 25th, 2015, 08:41 PM
scrubs
henery
1974
Thanks, lil embarrassed here, seems like two different styles n try to better understand the newer one.
1997 Defender 90 Soft Top - Dome Light Housing & Rear Speaker Housing pmkanitra Defender Technical Discussions 3 May 14th, 2015 05:55 PM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
LT230 extension housing swap red64chevelle Defender Technical Discussions 8 October 16th, 2011 09:09 AM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
New LT-230 in 87 Rangie, BINDING... HELP!!! h2eater Defender Technical Discussions 6 August 14th, 2004 04:35 PM
