LT 230 Questions... - Defender Source
Old October 13th, 2010, 08:57 PM
larsoncarl
Carl Larson
LT 230 Questions...
So I just swapped out the T case of a 99 Disco 1 auto into my defender. It was a low mileage donor and the case seemed like it was in good shape. I completed the swap, and the new case is stuck in low range. The linkage seems correct, but alas the high range will still not engage. My question is two fold, First is there something i am overlooking (one of the many sensors that I did not have in my D-90)? Second, can I unbolt the housing for the linkage and switch it into high range manually? This is a temporary case while rebuild the one I pulled with a GBR low ratio kit.
Thanks in advance,
Carl
Old October 13th, 2010, 09:02 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I'd exponent dropping the case and fixing off the truck. Much easier than on it.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 13th, 2010, 11:34 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
There is a silver top hat looking thing on top (above the center diff to the rear of the hi/low shifting lever on the case. of the Disco T Case, it has 4 bolts holding it down, it is a low/high interlock solinoid it needs power to let you shift from hi to low and back again, this power is supplier when the disco is put in neutral or park. Take it off and remove the solinoid inside the cover and put the empty cover back on. Sealed up of course.
Keith
Big, Red and ... aaa Red..
Old October 14th, 2010, 12:14 AM
larsoncarl
Carl Larson
Thanks, that is exactly what I am looking for... I was wondering what that was about... I even made a comment about how much smarter this is than my R380 defender case.
lt 230 and part time locker RoverJC For Sale - Parts 4 January 29th, 2010 09:06 AM
LT 230 Transfer Case WLDKGDM Wanted 1 June 16th, 2008 05:32 PM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Rebuilt or new LT 230 TC or best reference for prices... dmarchand Wanted 2 April 5th, 2004 06:17 PM
