LT 230 Disco ratio to Defender - Defender Source
Old January 24th, 2015, 04:40 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Dismanteling of both of the two follows the same way:
Just pull the all inner parts out ...
... have a look at special parts ...
... and carry on
At the end both of the ratios (Disco's is shown in front I beleave)
I thought it will make sense to put the Disco parts into the Defender case and vice versa to match the case numbers?
Nevertheless, the bearings inside the shown case (Defender) had had better days somewhere during the last centenial.
After using a dish washer parts are looking quite better.
First ring is set.
Will be set down to the formal deapth by the outer housing outset, when fitted.
Found just some seals that will fit together.
tbc.
Old January 25th, 2015, 04:21 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Assembling
Housing showing to the backside:
Just flipped 180°
Diff mounted verticaly in a vice by using soft spanners.
Low ratio gear, ...
... followed by the hub ...
... and the shifting ring.
Streetgear with its inner busch (ratio shown is 1,4):
The shifting ring has to be moved soft by hand!
It should fell down by its own weight when turning the wheel.
Pressed on taper roller:
Nut tied with 148Nm.
Ready to secure.
Fitted into the main housing.
Inside view:
Comming next:
The diffhousing
Old January 25th, 2015, 04:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Excellent.
Die Deutschen lieben für percision!
RDavisinVA
Old January 25th, 2015, 05:02 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Originally Posted by rdavisinva View Post
Excellent.
Die Deutschen lieben die Präzision!
Thanks!
But we lost the war.
Old January 25th, 2015, 09:56 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Perfect timing! I will be doing mine next weekend. My Ashcroft order is just waiting for pickup!
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 25th, 2015, 10:08 PM
Excellent.
I just had a really bad flash back to you trying to speak german in the rest in Ashville during Expo.
Old January 25th, 2015, 10:36 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Dieses Land Rover ist mit vier Zylindern Diesel ja!
You heard that about 25 times @ the Black Forest.
RDavisinVA
Old January 27th, 2015, 04:59 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Adjusting the Differential
Fit the distance into the bore. I used the original one (2,65mm thick)
Place the outer ring to the bore.
In fact you will use a shop press it might look like this (the shown taper roller is an old one, never try forcing the outer ring by transmitting force through the rollers!!!):
I use a big hammer and a brass pin for this.
Nevertheless, the outer ring has to be fit all the way down to the distance.
Fit the diffhousing to the main case and fix it with 4 bolts.
Engage any gear by hand using the shifter ring, roll up a rope arround the shaft, and set a luggage scales to zero.
Measure the needed force while the shaft is turning and write it down!
Grunt or just be happy if you are inside the tolerances!
Remove the diffhousing in any case to find a thinner distance (if you are over) or a wider (if you are under the limits) or, just like me to continue installing the inner parts of the diffhousing. Would like to say tomorrow. for joining.
Old January 28th, 2015, 05:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Diffhousing interior
Parts to be fitted:
Shifting ring in position.
Compress the spring and add it to the fork.
Add both of the two into the housing matching the ring inside.
Install the shifter rod.
Install the spring loaded ball as shown.
Compress the spring and fit one slotted washer.
Same procedure on the other side.
Close the reversing hole.
Old January 28th, 2015, 06:00 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Installing the diffbox to the mainbox
Remove the diff and fit the rod and fork.
Replace all together into the main box.
Inner view:
Seal the flange of the diffbox, ...
... secure the studs ...
... and get the parts married.
Tie down the nuts!
You may spin the inner parts by using the short shaft (no bearing on this part).
Fit another spring loaded ball as shown befor.
Old January 29th, 2015, 06:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Diffshifter and electrical Stuff
Parts and O-Rings
Just one of the three threads went through means only one of the studs needs to be sealed!
Have a look to the finger and the gap inside the rod when pushing down!
Try to shift the lock by using a 10mm spanner: only the rod will be moved! Moving the fork is forced by the preloaded spring!
Switch to let the difflock lamp light on.
Difflock opened:
Difflock engaged:
Old February 8th, 2015, 02:06 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Forgot to mention about the cover.
Liquid gasket does a very good job!
The bolts don't need to be secured by glowe because the inner threads are not running through!
Something special since the Td5, I guess? This switch's signal is a needed one for the central computing unit to reduce force if engaded. It's the same one used in all R380 gear boxes. Thread is M14x1,5.
Neutral positon:
Odometerdrive
Setting die, seal and housing (f.r.t.l))
befor setting...
and after. Very little force is needed!
Blue gear for the 1,4 ratio. New O-Ring!
Disco Td5 connector.
Defender version!
Old February 8th, 2015, 02:18 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hi/Lo Shifter Housing
parts:
Above older version, below Td5 version.
The function is the same as in every time:
A great torque transmitted by a shaft forces a rod to change the inner position of a fork.
New part: just an O-Ring
Parts only can be fitted in one position!
Done.
I protect the breather screw by a short tube.
Old February 8th, 2015, 02:25 PM
Looks great.
Kurt, regarding the "Odometerdrive", do these parts you show have a built in VSS so they just send a pulse without having to have the cable go to a VSS? I think this is what I need for my EV.
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2015, 02:35 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
New method to find out the needed distanz
Since the Td5 the taper rollers have to be positioned by a speacial LR tool, I don't have.
So I used some of commen measurements:
How to do it:
The tower 103,00mm high.
Both of the two taper rollers are fitted down to the inner securing rings.
Distance between table and upper inner ring set to zero.
Tower hight --> plus 0,21mm
Both of the inner rings are 21,99 wide.
The difference between the inner rings inside is to be calculated: 58,81mm
To get the correct force when screwing just reduce it by 0,05mm!
In this case the inner distance has to be 58,75mm long!
Old February 8th, 2015, 02:46 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Originally Posted by cgalpin View Post
... do these parts you show have a built in VSS so they just send a pulse without having to have the cable go to a VSS? I think this is what I need for my EV.
I'm not quite sure what a VSS might be, but you' re right they send a pulse; the cable doesn't work any more when using this. On the other hand, you need an electronical odometer!
What's an EV good for?
Old February 8th, 2015, 09:08 PM
Yes I'll be using a digital odometer so those would be perfect!
An EV (electric vehicle) is mostly good for driving
Old February 9th, 2015, 08:01 AM
i use the cheapo disco digital vss which seems to work ok.
Old February 10th, 2015, 03:33 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Distances for the intermediate shaft
Please call your local dealer!
Partnumber are listed from IEJ00020 to IEJ00400 stepping by the amount of 20 (20 different parts)
Starting at 58.35mm stepped by 0.05mm ending at 59.30mm.
Lower partnumbers fit shorter distances.
Old February 16th, 2015, 04:40 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
lrt-99-002
I gues I want one!
defender, disco
LT 230 1.4 ratio dogbite Wanted 2 March 1st, 2012 11:55 AM
1.2 ratio transfer case for 1995 Disco dave_lucas Wanted 3 August 13th, 2010 12:57 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Gear Ratio Calculator norros Misc. Chit-Chat 0 June 26th, 2005 10:54 AM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
