LS specific engine issues & discussion - Defender Source
Old April 20th, 2015, 01:59 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thought I'd start this as a seperate thread.
As I'm doing a freshen up of my cheap junkyard LM7 I've been learning a few things about these LS engines :
1. All early LS1's & iron blocks suffer from oil starvation to the passenger side rockers & pushrods, was fixed on later alum blocks. So, if you get a older/high mileage engine pull the rockers & check the pushrod tips for wear, they should be nice & shiny with no scoring
2. Most LS rockers use open cage bearings & it's common for them to loose needles. It's highly recommended to replace them, I'm using the Summit Racing bearing & trunion upgrade for a 100% fix, link http://www.summitracing.com/int/part...3002/overview/
Good link here about both issues Retro LS Build: Rocker Arm Trunion Upgrade | CC Tech - Corvette Blog, Restoration and Repair
Hope that helps !
------ Follow up post added April 20th, 2015 11:04 AM ------
If you want to do a basic cam upgrade these are the parts the guys on Engine Power used in their 4.8 budget build, made a decent difference for not a huge $ input :
Cam
http://www.summitracing.com/int/part...6-11/overview/
Springs
http://www.summitracing.com/int/part...8-16/overview/
And if you need them, followers
http://www.summitracing.com/int/part...skit/overview/
Plus the trunion upgrade as noted in my first post.
engine
Tech discussion- not Series or Defender Roverlab Misc. Chit-Chat 11 January 15th, 2015 11:48 AM
Stereo Discussion bradleyt09 Misc. Chit-Chat 13 October 3rd, 2013 10:10 PM
Great day ends with long Geico discussion COphinest Misc. Chit-Chat 9 July 19th, 2012 06:39 PM
2.5 petrol specific question mgreenspan Defender Technical Discussions 3 December 8th, 2009 04:19 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
