LR3 wont start - Defender Source
Old May 2nd, 2014, 11:27 PM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
LR3 wont start
Hi Guy's
My wife's 2006 LR3 wont start! This is the issue. When trying to start the car the hazard lights flash a couple of times and the doors lock and unlock again. There is also the red P from the parking brake flashing and the alarm light red flash.
I think it might be a bad wire or something else. I tried several forums and google but nothing that i could find was helpfull.
I tried to jump start it nothing i have the feeling its not the battery but a bad wire loose connection.
Any thoughts???????
Cheers Jeroen
Old May 2nd, 2014, 11:39 PM
The first thing I would check is the Transfer Case Control Module. It is located behind the battery and is likely filled with corrosion. If you remove the battery, you will see a black plastic cover over the module which has three connectors, remove the connectors and see if it is wet and/or green with corrosion. If it is you can try cleaning it, but you will likely need a new TCCM which requires SDD to program.
Old May 2nd, 2014, 11:46 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Jimmy, I think you missed your calling as a neurosurgeon. You are young though and still have time for med school.
Old May 3rd, 2014, 08:37 AM
Grover's Avatar
Grover
Check your battery. I had similar issues with a near dead battery.
Old May 3rd, 2014, 09:25 AM
Skool iz 4 foolz.
------ Follow up post added May 3rd, 2014 09:26 AM ------
Haha yeah, I forgot to mention to check the obvious things first. I can't tell you how many times I've spent a significant amount of time diagnosing something only to find a blown fuse.
Old May 3rd, 2014, 10:08 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
If it's NOT the TCM, which is an excellent suggestion, at what point does the truck go through the hazard and park brake light ordeal?
When you turn on the ignition just to run (not starting it) does it do the normal "system check in progress" screen and make its clicks and pops and other "start up" noises from under the truck? Do any faults show up on the screen?
Old May 3rd, 2014, 05:20 PM
Skeena river rover
jeroen
1997 300 TDI 110
Hi guys i just checked the module its clean and dry! So that cant be it. I attached a picture of the connectors. When trying to start the car the doors lock and unlock and the hazard light glash a cpoule of times. Nothing happens. Nobturn over nothing! Its like the car is in a security mode. The red p is flashing same as the red alarm light. So i believe it must be a wire or something like that. I can get the transmission in neutral etc still nothing happens.
Can it be because of the breaklight switch?
Old May 3rd, 2014, 05:21 PM
Skeena river rover
jeroen
1997 300 TDI 110
Ps there is no system check! Just the red p flashing and the red alarm light.
Battery is good!
Old May 3rd, 2014, 05:35 PM
Did you actually unplug the connectors to check for corrosion?
Old May 3rd, 2014, 05:51 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Jeroen, listen to Jimmy. His every word. You will be a happy man and most likely save a serious chunk of change.
Old May 3rd, 2014, 06:02 PM
I just thought of another thing to check. Look at the wires going into the parking brake actuator. I've seen a handful of those break right before the connector at the actuator. You should be able to access it from the right rear fender well. While I've never seen it, I've heard that the body harness connectors in the left fender well can get corrosion inside of them.
Old May 3rd, 2014, 11:39 PM
Skeena river rover
jeroen
1997 300 TDI 110
Update.
Ok i got it working! The connectors where dry and clean! No corrosion at all! After i replaced the battery (20 minutes or so) i tried to start the car and it worked! But it threw some faults, transmission went in Fault mode etc. I drove it for some feet and turned it off restarted the car and faults where gone!
But no my sunroof is not working. Very strange! But at least it is running again. Now what could it have been? I don't want to get rid of this car it never let us down! But we live way up north and we need a reliable car. There is no Land rover dealer for 1000 miles!
I will check for the other items you mentioned i hope that might be the case.
Great you guy's can help me out with your thoughts!
Cheers Jeroen
Old May 4th, 2014, 12:36 AM
I want an LR3 but stories like this scare me.
Old May 4th, 2014, 08:53 AM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I Would consider a nanocom or maybe someone else has another cost effective way to interface the electronics. Without it, you could have a 1000 mile towing bill for something you could fix under your shade tree. Just my $0.02
Old May 4th, 2014, 10:03 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
This one will be for sale in 3/4 months time, need to get the disco up to scratch first,
But to keep this reply to the tread yes a nanocom is very useful, and like all new vehicles you gotta keep the battery 100%
Name:	17-Apr-14 timberon spring 004.jpg
Old May 4th, 2014, 10:27 AM
Hold the either the open or close button (I can't remember which one) down until the sunroof goes through its full travel. It will take about 30 seconds for it to start moving.
Old May 4th, 2014, 11:03 AM
navydevildoc
Neill Thornton
Truck must be running. Hold the close side of the switch for 30 seconds. This re-calibrates the sunroof computer (yes, the damn sunroof has its own computer). It may move during this procedure, or it may not.
Use a watch to ensure you hold it for at least 30 seconds.
It will probably start working after that.
Old May 4th, 2014, 11:05 AM
navydevildoc
Neill Thornton
They are actually really good trucks. Mine's at 165,000 miles now and I just did the most complex repair yet, which was replacing the water pump.
I do however have a BlackBox Faultmate. Anyone really serious about taking these offroad needs to have one. Simple electronics glitches, while rare, can disable huge swaths of the off-road systems. If you have something like a faultmate you can be back in the game in just a few minutes.
Old May 4th, 2014, 05:48 PM
Skeena river rover
jeroen
1997 300 TDI 110
It has been a great car so far! Never had any issues or break downs. So i was very surprised it was not starting.
Ok i tried to recalibrate the sunroof, no luck! I tried while driving, running engine etc nothing happen't
Checked the fuse was also ok. I have no clue was wrong with it.
I will buy a fault reader to see what is wrong with the car. What would you guy's suggest?
Thanks for all the feedback!
Old May 4th, 2014, 07:17 PM
roverman2010
1985 LR 90 200Tdi
Do a search on the D3 forum
http://www.disco3.co.uk/forum/index.php
lots of info
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
lr3, start
93'D110 wont start has code #20 MRROVER Defender Technical Discussions 5 January 14th, 2010 08:35 PM
STILL wont start texmoto Defender Technical Discussions 0 June 29th, 2009 08:42 AM
truck wont start jimmy salmon Defender Technical Discussions 26 December 3rd, 2008 01:44 PM
Yet another Truck Wont start... arbik Defender Technical Discussions 12 September 21st, 2006 03:51 AM
HELP - D90 wont start....going camping on Thurs TurkD90 Defender Technical Discussions 6 July 25th, 2006 09:49 AM
