Lr3 suspension fault - Defender Source
Old June 28th, 2014, 11:22 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
The wife's lr3 amber suspension fault just came on. Initially it sounded like the compressor was running so I pulled the fuse. Locked up the car and went to the store. When I unlocked the door a rush of air exited in the rear somewhere, fault still on.
Drove down the road, locked it up. Upon returning (fuse still out) Amber fault turned off. Went to another store and when I unlocked the door heard the rush if air again and fault turned back on, fuse still out.
I'm on the road so limited access to tools.
Owners manual says it's okay to drive on the amber light but still have many miles to go.
Anyone know what may be causing the fault?
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 28th, 2014, 01:57 PM
lordhelemt's Avatar
lordhelemt
Paul
Compressor is shot.
Old June 28th, 2014, 02:31 PM
Grover's Avatar
Grover
Is the comp running?
Old June 28th, 2014, 02:37 PM
lordhelemt's Avatar
lordhelemt
Paul
The compressor wouldn't stop running so I pulled the fuse. At the dealer now and the compressor is leaking from the housing. Have a new compressor installed now
Old June 28th, 2014, 03:11 PM
Grover's Avatar
Grover
That sucks dude...at least you were not stranded in the middle of nowhere...
Old June 28th, 2014, 07:06 PM
jafir's Avatar
jafir
Jafir Elkurd
Did you keep the old compressor?
Old June 28th, 2014, 09:59 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Fyi...You meed to pull two or three fuses to shut the whole system down not just the compressor fuse. I sold my lr3 2 and half years ago and it was prob another 1-2 before that when I went through similar problems. I can tell you it will slowly self level in the downward direction with no compressor unless you pull the others.
Ryan
84 110SW County LHD
07 L322 Vogue
Old June 29th, 2014, 09:14 AM
lordhelemt's Avatar
lordhelemt
Paul
No, left it at the dealer.
Lr3 suspension Rugbier Misc. Chit-Chat 30 October 22nd, 2014 11:57 PM
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
LR3/LR4/RRS Air Suspension Compressor Blowout discojosh2000 For Sale - Parts 0 December 30th, 2011 09:51 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
