LR Heavy Duty Front Springs - Defender Source
Old February 6th, 2013, 01:45 PM
surf110's Avatar
surf110
Ze
130 Project
Does anybody have a part numbers for the Genuine HD front springs?
Hoe much lift should I expect from those?
Old February 6th, 2013, 01:53 PM
I think HD relates to supporting extra weight ... like a winch and big bumper ... with these items, lift should be marginal
Old February 6th, 2013, 02:17 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://landroverparts.roversnorth.co...x?code=RNK5102
Ze,
Based on your engine I was told that these springs will lift 1" above factory. Les @ RN quoted me these and Bilstiens....
Old February 6th, 2013, 02:31 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
length, Rate, Coils, color
NCR8044 f-left 15.13, 155/215 9, white/white (progressive)
NCR8045 f-right 14.49, 155/215, 9, Yellow, yellow (progressive)
NRC9448 f-left 15.31, 225, 8, Blue/ red
NRC9449 f-right 14.80, 225, 8, Yellow,/ white
To get more of a lift you will have to go to an aftermarket spring or a spacer. If your springs are old they may be sagging a bit. It will also make a difference if you are running a diesel or gas motor, the above springs were for diesels.
Land Rover 110
Old February 6th, 2013, 02:43 PM
http://www.red90.ca/rovers/springinfo.html
Old February 6th, 2013, 03:27 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
FWIW... "heavy duty" 90 front springs, are in fact standard 90 rears (Same part number)
So getting some shouldn't be too hard.
Old February 6th, 2013, 07:12 PM
surf110's Avatar
surf110
Ze
130 Project
Thanks fellows. Figured out I already have the HD springs.
GBR heavy duty front shafts/CVs! crown14 For Sale - Parts 2 February 9th, 2011 12:26 PM
Are front springs handed Cmikefly Defender Technical Discussions 1 March 30th, 2010 03:52 PM
ARB M002 Heavy Duty Wiring Loom Troys Defender Technical Discussions 1 December 15th, 2006 03:55 PM
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
Bearmach Springs Heavy Duty... h2eater For Sale - Parts 0 July 9th, 2004 12:40 PM
