LR Glow Plug relay temp? - Defender Source
Old June 9th, 2004, 01:42 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Does anyone know the temp the glow plug relay (LR genuine) operates at? I realize the glow plug operates at all times, however I was told the light portion (to the dash startup) of the relay only kicks in under a certain temp. I put the relay in the freezer but had no luck (no surprise since the freezer isn't that cold). The light isn't kicking off no matter what is tried. So right now it's hard wired to operate based on the power to the glow plug (bypassing the light portion of the relay).
Any thoughts are appreciated.
relay
Glow plug wiring differences ... Retrofit Defender Technical Discussions 44 January 16th, 2012 10:44 AM
Diesel Ignition switch with glow plug tomaco1 Defender Technical Discussions 18 December 31st, 2011 02:31 PM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 05:51 PM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
