LPG adapter - Defender Source
Old April 24th, 2012, 03:20 PM
atpick's Avatar
atpick
Andy
1990 110
LPG adapter
Does anybody know where I can find one of these here in the U.S.? Propane is only $2 a gallon here! I need an adapter for my British LPG filler to convert it to 1 3/4 inch ACME filler. Just like the one here on this website. http://www.autogasshop.co.uk/lpgauto...apters-1-c.asp
I believe it's the flush filler to 1 3/4 inch ACME. Anybody stationed in England that could grab one of these for me and MPS it to Cannon AFB and I'll pay pal you.
Cheers,
Andy
Name:	2011-06-08 18 18 59.jpg
Old April 24th, 2012, 03:29 PM
Why can't you order it from that web site?
Old April 24th, 2012, 04:48 PM
Naplm00
Matthew
holy crap $2 a gallon? im paying 3.40 a gallon when i buy 400 gallons or more cash
Old April 24th, 2012, 06:58 PM
Yeah I haven't seen near $2 either unless you sign up with a distributor, have a fleet and can get the tax credit as well. Even then it was $3 or so.
Old April 24th, 2012, 07:35 PM
atpick's Avatar
atpick
Andy
1990 110
When I tried to order off the website, it said that they only shipped to British or European addresses, otherwise I would have done that. $2.10 a gallon here in Clovis, NM to be exact, not bad!
Old April 25th, 2012, 06:15 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Andy, why can't you remove the UK beyonet fitting and replace it with a US style fitting.
If you do run on propane you will need to drain the vaporiser more often as propane is normally much "dirtier" than LPG, I ran on free Propane for over a year.. good times.!
you should find the parts you want locally try a forklift service place as many forklifts run driectly from propane cylinders & will therefore have the correct fittings.
If you are stuck & know the fitting you want you can get it mailed to me & i'll forward it on.
regards all
Gren
Old April 25th, 2012, 06:33 AM
Dumb question. CNG is more common for vehicles than propane. What is your vehicle set up to run on?
Old April 25th, 2012, 11:55 AM
atpick's Avatar
atpick
Andy
1990 110
Thanks all for the inputs. A board member stationed at Mildenhall has offered to be the surrogate of the part I need. @Rocky, my truck is set up to run on normal gasoline or propane. There is an electric switch up front to switch back and forth between either and also a simple electronic gauge to indicate how much propane remains in the tank. As mentioned before in runs under pressure from the tank through a vaporizer into a special modded piece fitted to both carbs. That's about the extent of my knowledge, but I'm sure someone on here is much smarter than me.
Old May 22nd, 2012, 07:12 PM
atpick's Avatar
atpick
Andy
1990 110
Finally got my part in today and filled up with Propane. Thanks to fellow board member Mgreenspan for being the courier for the part. However, when I switch to LPG every now and then it idles way too low. I think it is running too rich due to the high altitude here. Anybody on this board know anything about LPG setups or how to change the mixture settings?
Old May 23rd, 2012, 04:42 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Andy,
Before you do anything warm the car up and drain the vaporiser, there will be a screw or bolt in the bottom of the housing, slow idle & poor pick up when running on gas(LPG) is a symtom of the diaphram being slowed down by excess oil.
You change the mixture on LPG systems by adjusting tension on the diaphram in the vaporiser, there should be a screw or small bolt set into the center of one of the faces, have a look to see what brand of vaporiser you have and then google the set up instructions.
When running on gas I found the ignition needed to be advanced for best running I used to do it by ear after I had serviced the car.
Regards
Gren
Old May 23rd, 2012, 06:18 PM
atpick's Avatar
atpick
Andy
1990 110
Awesome, thanks for the info! It ended up being a little more simple. Turns out I was switching to LPG too quickly from petrol. Once I allowed the normal gas to "run out" of the carbs in the center switch position, I switch over to LPG just before it conked out. Once I do that it runs perfectly. I think it was too rich from running on both regular gas and LPG at the same time which was a result of not waiting before switching.
Cigarette Lighter adapter boshea Defender Technical Discussions 17 October 19th, 2007 05:41 PM
Steering Wheel Adapter thelandroverguy Defender Technical Discussions 19 May 8th, 2005 07:16 PM
ARB adapter D110 JackW Defender Technical Discussions 0 March 13th, 2005 10:15 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
