Lowering Gas Tank - Defender Source
Old May 5th, 2010, 04:19 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Lowering Gas Tank
I have searched forum, and couldn't find an answer to some previous posters with my same question:
How far can I lower my gas tank before the shorter of the lines/hoses start binding and possibly disconnecting themselves?
------ Follow up post added May 5th, 2010 04:59 PM ------
no one has done this? I need to replace the vent hose and don't want it to become a "might as well"
Old May 6th, 2010, 08:26 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
your restricted by the filler hose on the right side so maybe 3 or 4 inches. you should have enough room to do the change. make sure the tank is close to empty as they can be hard to handle with gas slopping around. I supported mine with a 2x4 and a floor jack.
Its a good time to clean the frame behind the tank as they usually have a bunch or crap built up.
Old May 6th, 2010, 09:52 AM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Thanks Ron, the floor jack and 2x4 was exactly my plan, as was running it down to fumes.
I appreciate the help
Old May 6th, 2010, 01:31 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Do you would just undu the fill neck, take the 2x4 length wise and lower / support with the floor jack?
Old May 11th, 2010, 12:48 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
So I did this by myself yesterday, and was going into it optomistic, as the PO had recently replaced the tank guard, and the truck is pretty rust free. Only once I got under there and really looked, one of the bolts in the xmember had already been sheared off, and in getting the 2nd out, I manged to break that one. All 4 bolts directly under the tank were fine.
My rig is my only car currently... Am I going to be ok driving (and filling the tank) without the two crossmember bolts? Should I only fill 1/2 way until I get them pulled out and replaced? I'm trying desperately to avoid having to drill/ retap as I have limited tools and no experience.
thanks
Old May 11th, 2010, 12:57 PM
It is not going to fall off, but you should drill and tap as soon as possible.
Old May 11th, 2010, 01:02 PM
Should be fine for street driving short term since the guard is new but long term I'd drill/tap and replace the missing ones.
gas, gas tank
Condensation in gas tank Antonios Defender Technical Discussions 25 March 25th, 2006 09:38 PM
WTB: NAS 90 rear gas tank headdamage Wanted 11 March 8th, 2005 02:46 AM
Stainless steel gas tank skid plate dave_lucas For Sale - Parts 27 December 26th, 2003 11:48 PM
