lowered shock towers - Defender Source
Old December 9th, 2007, 08:23 PM
cdb
Clark Bowen
Has anyone used the Rovers North 2" lowered shock towers?
http://www.roversnorth.com/store/pc-...8-2-lower.aspx
Did they improve articulation?
How were they with Bilstein shocks? (what I have now)
Are there any other shocks that might work better?
Did they compromise or change the onroad handling or ride (I assume it got a bit harder).
Looking at videos of me going down and up Wipeout Hill I could see that I don't have that much front end downward articulation but I don't want to go to 3 link or compromise my onroad driving. This seemed like a solid reasonable way to add 2" of droop.
Clark
Old December 9th, 2007, 09:46 PM
Why not just run longer shocks?
Old December 9th, 2007, 10:04 PM
cdb
Clark Bowen
Good question.
Any recommendations?
Clark
Old December 9th, 2007, 10:24 PM
If you have a lift, something with 10in of travel. I always like bilsteins, get the model that suits your budget. 7100, 5100 etc.
Old December 9th, 2007, 10:34 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
especially for $180.
because six cylinders will take us farther than any president
Old December 10th, 2007, 12:52 AM
cdb
Clark Bowen
Has anyone actually used the Bilstein 5100s or 7100s? I looked at the Bilstein site and it says they are only loop to loop on the mounting. They don't even show an application for Land Rover in those models.
I couldn't find them on the store sites either.
Am I missing something because I liked the Bilstein idea.
Clark
Old December 10th, 2007, 02:13 AM
oldscratchggf
nate
95 d90
Clark
loop style mounts available through rovertym for cheap.
Old December 10th, 2007, 10:20 AM
cdb
Clark Bowen
Thanks.
I'll them.
Clark
Old December 10th, 2007, 01:47 PM
cdb
Clark Bowen
I spoke with Rovertym and with the Bilstein 7100s I'd need new upper and lower shock mounts plus the $$$ for the 7100s.
Decided that the Bilsteins might mean more mods necessary - longer brake lines and bump stops plus having to maintain a rebuildable shock.
RoverTym said the lower shock tower would work for my needs and so I decided to go with the 2" lower ones from RN.
Thanks for your help,
Clark
Old December 10th, 2007, 01:54 PM
You could have run the standard eye to stud 10in shocks with disco II towers on top or used a stud to stud in 10in. I had warn shocks in that length at some point.
On the plus side the RN units are quite beastly looking and will not rust out like stock.
Old December 10th, 2007, 03:13 PM
what are the tradeoffs if any of going with the lowered shock towers? I am thinking the same thing as an option when going with an OME 2" lift, but don't understand the downside.
Old December 10th, 2007, 03:39 PM
oldscratchggf
nate
95 d90
Clark
Shouldn't need new upper mounts, should only need new lower mounts front and rear. Only reason you'd need new upper mounts is up front if you get reservoir shocks.
longer brake lines would be necessary with the 2" lower shock towers too- you are still increasing the potential travel.
whatever though.
there was no downside, per se, so much as it's a matter of why drop $180 on the towers, why not drop $180 on new longer shocks?
Old December 10th, 2007, 03:44 PM
Downside is that you risk bottoming out the shock on compression. Everyone I know goes with TALLER not shorter mounts and runs longer shocks.
Old December 10th, 2007, 03:46 PM
oldscratchggf
nate
95 d90
i dont know why i didnt think of that, especially considering part of the reason I went for the 10" Fox up front when I redid the suspension on my old truck was because my Ranchos were bottoming out.
Old December 10th, 2007, 04:02 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
i lowered the mounts at first and did not lengthen the lines. eventually i poped a line on a trail and it was no fun getting off the mountain. in hindsight i'd wish i'd had Ron's advice. makes more sense to me now.
Old December 10th, 2007, 04:40 PM
Lesson one: listen to evilfij. It may not make sense at first, but eventually it will all come together.
If you extend travel you should invest in longer brake lines. Heck, everyone should have longer stainless steel brake lines as 10 years is about all stock rubber lines should be permitted to be on a truck.
Old December 10th, 2007, 04:41 PM
yah, arent' there lowered bumps stops avaiable too?
Old December 10th, 2007, 04:44 PM
Yes, extended bumpstops. RN sells them or get them from Poly performance.
Old December 10th, 2007, 04:50 PM
heh. alas, my vehicle still iies dormant somewhere in NJ. But i did get a set of stock towers with some bilsteins attached. The towers will go off fo dipping along with everything lese, then I will follow your sage advice for not using the $$$ lowered mounts!
Old December 10th, 2007, 07:44 PM
cdb
Clark Bowen
I already have stainless steel braided longer brake lines and I did ask RN about any issues with the shorter towers and they said there were none - including bottoming out or a hard ride.
So, I guess I'll fit and check.
Clark
D2 upper shock towers and eye style lowers mightymg For Sale - Parts 4 October 6th, 2009 08:41 AM
Equipe lowered shock mounts CDeWan For Sale - Parts 1 April 28th, 2009 05:02 PM
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
16x10 steel wheels/DiscoII shock towers WillT Wanted 6 August 2nd, 2005 01:12 PM
Galvanized stock shock towers... dmarchand For Sale - Parts 1 May 22nd, 2004 04:28 PM
