Lower Steering Shaft - which one to use? - Defender Source
Old August 29th, 2014, 11:03 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
For my project I'm starting to piece together items onto the bulkhead and will probably start the steering end of things at some point soon.
Here is a link to the different options: http://www.roversnorth.com/Land-Rover-Parts/985
It looks like NAS style is: RTC4738
But ROW is: QME500031 - lrseries.com says that part number is Defenders up to 2006
Is one design better than the other? Does the NAS one "break" away when in an accident?
Cost wise it looks like the QME500031 is all one piece while the RTC4738 will need upper and lower U-joints.
I am using an Adwest PS box from a Disco I. Upper steering will be either pulled from the old truck or I might go 48 spline.
Thanks in advance for any input.
ID:	101775   Click image for larger version
Old August 29th, 2014, 11:53 AM
The one piece is the Td5 part. That is the one that clears a disco 200tdi down pipe on the left. Otherwise, they are both compress designs in the event of an accident. Not sure one is better than the other.
Old August 29th, 2014, 12:07 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
If it matters, the NAS one meets US FMVSS (pre-SRS mandate) and compresses further than the ROW.
Old August 29th, 2014, 01:43 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Doug - my OM617 oil cooler lines are right there so if the ROW one is tighter it might work better. Might not be that critical tho.
------ Follow up post added August 29th, 2014 01:47 PM ------
Thanks for that info Crown - I guess that is what I was meaning in that question in my original post. It looks like in the event of a heavy enough crash it breaks away by design. Good to know that piece of info.
Will need to take a closer look when I get home tonight and see what sort of clearance I need with those lines. They are AN stainless so I should be able to figure something out.
Lower steering column, steering shaft transientmechanic Wanted 6 August 21st, 2013 07:54 AM
Which side markers to use? Maximal Defender Technical Discussions 3 February 18th, 2013 09:21 AM
Which Steering Wheel to use? Rosproline157 Defender Technical Discussions 6 December 7th, 2011 07:24 PM
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
Which Tuffy boxes do you use? DiscoDino Defender Technical Discussions 4 January 21st, 2005 06:04 PM
